97 accord pas window randomly stops working help..
So my pas window randomly works.. I just replaced the master switch andthe motor is used salvage yard motor.. Why does it only work sometimes? Short? Old motor? What....!
Re: 97 accord pas window randomly stops working help..
Look for broken wire(s) in the wire boot. It looks like a rubber accordion and is situated between the door hinges.
As an owner of 3 different 94-97 accords, I will tell you that the window motors are a weak point in these cars, the mounts are in the middle of the window, instead of at each end so it always ends up with more friction on one end, which causes the motors to burn out prematurely. If you got one from a junk yard there is a pretty good chance it is on its way out too, I would look into a new one, or try to find a low mileage used one.
Silicon grease works wonder on sluggish windows. Both windows on my 94 Accord practically stopped working until I applied some silicon grease. Now they work like new.
He knows where you live!
For the actual metal rails, use a lithium grease (Honda has a spray) for these. Clean them out thoroughly before you just spray it though.
mickyandmickey
05-12-2008 05:13 AM
