96 accord shifting hard
Old 02-17-2010, 02:54 PM
Casp3r88's Avatar
Icon6 96 accord shifting hard
i got a 96 accord and it shifts hard when shifting from park to drive any solutions to this problem?????????
Old 02-17-2010, 05:58 PM
mutiny93's Avatar
Default Re: 96 accord shifting hard
get a manual?
Old 02-17-2010, 06:14 PM
He knows where you live!
TheMuffinMan's Avatar
Automatic I take it.
Change the transmission fluid with some fresh Honda ATF. Think it's 2 bottles? That should help the shifting quite a bit. It probably won't solve the issue, but will definitely be helpful.
Old 02-18-2010, 10:29 AM
Lloyd Xmas's Avatar
Originally Posted by mutiny93
get a manual?
I really hate seeing post like this. The purpose of this tech forum is just that, to ask technical questions related to our Hondas.
Old 02-18-2010, 12:04 PM
mutiny93's Avatar
sorry i was just bored. wont happen again.
Old 02-18-2010, 09:54 PM
fastlane2's Avatar
Funny.
Anyway I'd check the:
1. Kick down cable make sure it just closes the valve and make sure the trottle doesn't move the and the cable takes a 1/8 throttle to start moving(a delay). This cable affects the line pressure going to the transmission and will affect shift quality if its off a lot. Us a 12m wrench.
2. Fluid as mentioned
3. The grounds by the battery. The one on the frame and the one connected to the transmission near the bottom. Because the 4 solenoids are grounded to this wire.
Old 03-05-2010, 04:10 PM
Casp3r88's Avatar
thanx alot......
Old 03-10-2010, 04:40 AM
Casp3r88's Avatar
Icon6 Re: 96 accord shifting hard
i have another question umm??? can the honda civic fuel pump work in a accord?
Old 03-11-2010, 09:44 AM
fastlane2's Avatar
Technically any pump will work as long as you can attach it to the sender unit and as long as the pump supplies enough fuel (flow rate) and the pull on the electrical system matches ( amps). Its not recommended if the pump #s are different but I'm putting a GM pump in a BMW 535i to save $300
shyne89
11-18-2013 03:24 AM
da_dude
05-10-2010 05:25 AM
AceNN
Classic Hondas
05-27-2009 02:39 PM
andres2283
03-09-2009 08:07 PM
mrak
02-05-2008 05:01 PM
Quick Reply: 96 accord shifting hard
