Valve cover grommet help
Old 10-17-2005, 06:51 PM
Excelerate's Avatar
Default Valve cover grommet help
Maybe this is the dumbest question ever but how do you get the valve cover grommets onto the valve cover bolts? The metal cap fits but the grommet is not wide enought to fit over the bottom part of the bolt so how do I get the grommet over that bottom part?
Old 10-17-2005, 07:01 PM
P_Adams's Avatar
Default Re: Valve cover grommet help (Excelerate)
Soak them in hot water to soften them. Apply a light coat of oil to the bolts and...............Phfffft, they're on!!!
P
Old 10-03-2007, 10:00 PM
jaysome01's Avatar
Default Re: Valve cover grommet help (P_Adams)
I'm having the same problem right now.. Is this true? Throw it in some hotwater and lube up the bolt and I should be good? I broke 3 grommets right now and I gotta re-order. 10 bucks each from Honda... SUCKS!!!
HELLLLLLLPPP!!!
Old 10-04-2007, 03:48 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: Valve cover grommet help (jaysome01)
I've never tried soaking them in hot water.
I usually put a little oil on the bolt and then take the bolt, grommet and a socket and place them between a vice in this order...
vice l bolt > grommet > socket l vice
then I just tighten the vice up slowly until the bolt pops through the grommet.
It's much easier than trying to muscle them through with your hands.
Old 10-04-2007, 06:09 AM
Duane_in_Japan's Avatar
Default Re: Valve cover grommet help (TouringAccord)
10 bucks for an OEM Honda rubber Grommet, just one, I need to get into the grommet business, I only use OEM (JDM) grommets and never had to pry one on, always have to force off the old ones though.
Old 10-04-2007, 08:35 AM
jaysome01's Avatar
thats how i tried it the first 3 times.. but 3 broke.. I'm going to try and make some special washer or something to make the bolt more "pointy" instead of having the flat surface on the bottom of the bold and trying to get the grommet thru there... Oh well, just ordered 3 more grommets!!! Imma give it another try.. If anyone else has more info please send.. This is really aggrivating...
Old 10-05-2007, 09:16 PM
jaysome01's Avatar
I Finally Got it!!!!! I received the new grommets from TAS Auto.. Great site!!! I did have to make a "SPECIAL" Washer that mimicks the other side of the threads... I can take a picture of it if someone wants.
Old 10-06-2007, 06:24 AM
PLEASE, every pic added to the site is a plus.
Old 12-02-2009, 03:26 PM
jdbwood's Avatar
i was in the same dilemma goin nuts about this.. broke 2 gromments and had to be stuck witout car.. hot water trick worked great on these cheap fel pros thanxx p adams
99accordsedanforsale
Classic Hondas
11-12-2007 07:24 AM
k_lude
01-09-2007 06:48 PM
SlowB16si
01-28-2006 02:13 PM
hcivic99
06-08-2005 06:15 PM
LoudAccord
01-09-2003 10:43 AM
Quick Reply: Valve cover grommet help
