94 Accord EX- need a fuse box diagram
Old 04-11-2009, 03:24 PM
fortune.cookie22's Avatar
Default 94 Accord EX- need a fuse box diagram
I looked everywhere, and it's possible I just plain don't know what it's supposed to look like, but I think I need a diagram of the fuse box for my car- the one in the car, not under the hood. I bought the car last night, and it turns out neither of the front blinkers work, and I can't figure out why the CD player (aftermarket) won't work either. I thought a good place to start for both (open to suggestions of otherwise) would be fuses. I'm pretty new to working on cars, so please bear with me if I have stupid questions. Thanks so much!
Old 04-11-2009, 03:26 PM
New User
Active_Matrix's Avatar
Default Re: 94 Accord EX- need a fuse box diagram
It should be on the fuse box door in the car!
Old 04-11-2009, 03:30 PM
redbull-1's Avatar
Yes, it should say inside the door of the under dash fuse box.
If you don't have the owner's manual for other things, you can view it here:
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
Old 04-11-2009, 03:53 PM
FunnyVictor86's Avatar
do your hazard lights work?
Old 04-11-2009, 04:10 PM
Wow, I feel pretty silly, thanks! Now the problem is, all my fuses are fine, I still don't have front blinkers, and my CD player still doesn't work.
Old 04-11-2009, 04:11 PM
The hazards work, but only the back ones.
Old 04-11-2009, 04:24 PM
im sure you already checked the bulbs ... but when you put your blinker, does it blink at a fast pace or normal ... i would use a volt meter and see if your even getting power to the blinker sockets
Old 04-11-2009, 04:38 PM
redbull-1's Avatar
So are all the turn signal lights out in the front (i.e., the lights in the bumper and the corner parking/side markers)? If so, it may be the turn signal/hazard relay located in the under-dash fuse/relay box.
You might need to check the aftermarket radio wiring. Here is a link to instructions to access the radio.
http://www.installdr.com/InstallDocs...PDF/466037.pdf
Old 04-11-2009, 04:41 PM
Yes, I did check the bulbs, haha. They blink fast. *sigh* time to call the ex with the meter.
Old 04-11-2009, 05:06 PM
but aren't the front and rear turn signals running on the same relay? correct me if im wrong but if it was the relay none of them would work right?
Old 04-11-2009, 05:18 PM
redbull-1's Avatar
Yeah, the front and rear signals run off the same relay.
The fast blinking may be due to a bulb burnt out in front or going out, or corrosion in the sockets.
Old 04-11-2009, 06:08 PM
Oh I meant that in the car, like, the little indicator lights in the dash blink fast. I have no blinking action outside the car. I have headlights and nothing else, no corner blinkers, no bumper blinkers, nothing.
Old 04-13-2009, 04:16 PM
All fixed- thanks so much!
Old 04-13-2009, 04:30 PM
redbull-1's Avatar
Just out of curiosity, what fixed it?
Old 04-13-2009, 06:16 PM
Pretty much new sockets all around. Although now my left headlight won't work, and when you put a bulb in it it takes out the rest of the lights on the left side, so I am assuming there is a bad ground in there somewhere; I will be checking that out Wednesday.
Old 04-13-2009, 06:40 PM
redbull-1's Avatar
Yeah, maybe a ground wire, as the headlights & passenger turn signal share the same ground.
Old 04-13-2009, 06:45 PM
redbull-1's Avatar
Check the ground here.
Old 04-14-2009, 06:02 AM
I will check that out for sure, thanks for the diagram it helps a ton!
Old 04-14-2009, 04:47 PM
Once again, all fixed.
Old 04-14-2009, 04:50 PM
redbull-1's Avatar
I'm glad. Was it the ground?
Also, was the CD player ever fixed?
Old 04-15-2009, 05:59 AM
It was indeed the ground, as I had suspected. No, I still have no working CD player though. I think I am tackling that tonight. We checked all the fuses, connections etc. and everything seems to be in order, so we checked out the head unit itself, and it works fine in another car. Yesterday messing with it a little it made the "hey I'm on" noise once, then nothing, so I'm not really sure what's up with it, but I do know that driving to the sound of my own leaky exhaust is getting irritating.
mtnblue
03-29-2016 02:05 PM
ProjectCD5
03-19-2009 08:12 AM
03hondaguy03
05-09-2007 09:11 PM
svselva
09-29-2005 07:37 PM
Ricta
11-15-2004 08:59 AM
Quick Reply: 94 Accord EX- need a fuse box diagram
