92 accord, used stop leak and now car overheats.
Old 03-02-2011, 01:15 PM
88fourdoor's Avatar
Default 92 accord, used stop leak and now car overheats.
pretty self explanitory my car had a coolant leak around the back of the thermostat housing where that pipe comes out and proceeds to run across the back of the block so i tried some bars stop leak and only used half the pellets like the bottle said for a 4cly, well followed the instructions and blamo it stopped the leak, but now coolant is not circulating through my engine, the top and bottom hose arent clogged, i removed the thermostat, its not clogged, when i removed bottom hose from the block it was full of fluid and it all ran out when i took it loose from the rad. and i even run water thro the rad, its not clogged, my only guess is that the stop leak jacked up my water pump? is that common in accords? or any common places for it to clog the system up? i need help i have new water pump anyway but if its not going to help then i dont want to change it just yet.
Old 03-02-2011, 02:12 PM
Nicefeet's Avatar
Default Re: 92 accord, used stop leak and now car overheats.
Radiator tubes are partially clogged with stop leak.
Stop leak is garbage.
Old 03-02-2011, 03:01 PM
CDdubz5's Avatar
well i guess you learned your lesson. it is possible that it has either clogged the block, the water pump or other hoses. i guess since you have the pump, try it?!
Old 03-02-2011, 07:54 PM
quickster's Avatar
aw man, that would have been so easy to fix too...there is an O ring that goes in between that pipe and the housing. Would have been like $2 and an hour of your time to fix it.
Old 03-04-2011, 03:59 PM
poorman212's Avatar
Did you start the car with the t-stat out? You say "i removed the thermostat, its not clogged"...did you throw it in a pan of water or spend the ~$5 on a new one? Worth a check before replacing the pump/t-belts/ect.
acbettis
04-26-2018 12:33 AM
Yao Saechao
03-26-2018 01:25 AM
my97accord
01-31-2005 05:20 AM
surephase
05-10-2004 05:44 AM
Quick Reply: 92 accord, used stop leak and now car overheats.
