92 Accord timing belt
Old 11-21-2013, 07:03 AM
Honda cd65's Avatar
Default 92 Accord timing belt
Hi, - timing belt condition/milage is unknown so I suppose I sit behind a time b**b?
Old 11-21-2013, 10:14 AM
NZXTInerTia's Avatar
Default Re: 92 Accord timing belt
Wut.
Old 11-21-2013, 11:28 AM
Honda cd65's Avatar
Originally Posted by NZXTInerTia
Wut.
Hahaha NZX, - I suppose I did sound odd in that headlining post but let me
put it this way:
Sometimes while driving I feel quite uncomfortable when I come to think of what
condition/milage the timing belt might be in.....Should I be concerned?
Old 11-21-2013, 08:01 PM
MM Gruppe B
MAD_MIKE's Avatar
If you have no paper work, and there is no sticker under-hood indicating when the belt was replaced, plan on replacing it. If that belt breaks the engine is an interference type, the valves will make contact with the pistons and bend requiring a head rebuild.
If mileage/time unknown, replace belt.
Old 11-21-2013, 10:07 PM
holmesnmanny's Avatar
At the very least, pull the valve cover and look at the belt as it sits on the cam and then use a 19mm socket on the crank bolt and turn the crank a full turn looking at the belt. If you want, take pics of the belt(the ribbed side) and show us. You'll want the car in neutral obviously.
It's a lot easier to turn the engine with the spark plugs removed.
dleccord
04-13-2020 08:03 AM
spazman2099
11-13-2014 04:27 AM
thegatekeeper14
08-05-2009 03:28 PM
integra3586
09-25-2006 03:57 PM
Quick Reply: 92 Accord timing belt
