1997 Honda Accord Electrical Problem????
Old 02-11-2010, 09:28 PM
vikki4567's Avatar
Default 1997 Honda Accord Electrical Problem????
After doing a Vtech head swap on my 1997 Honda Accord, the main wire on the alinator touched a ground and sparked.... the dash lights flash, the main relay just clicks, the speedometer and tachometer bounces when trying to start.... sometimes it will actually start but runs like crap and will not go out of gear....
I have replaced the main relay but that did not fix the problem....
I can not figure out what the problem is??????????????????
Old 02-11-2010, 10:07 PM
TheAsian's Avatar
Default Re: 1997 Honda Accord Electrical Problem????
First off check all your fuses. Check FUSE 15 In the engine bay. What you did has a very good possibility that you fried the ecu, or burnt up a ground wire. So check all the grounds in the engine bar. Block, trans, and the battery ground.
But from what you are describing it sound like the ECU fried so, try swapping w/ someone once you are sure all your grounds are good.
Old 02-12-2010, 12:56 PM
vikki4567's Avatar
thank you i will try that
Old 02-15-2010, 06:46 PM
vikki4567's Avatar
ok i did that bought three new ecus and still dose the same thing any other suggestions???
Old 02-15-2010, 07:00 PM
redbull-1's Avatar
Sound kind of like a ground is not connected or fully connected.
Old 02-15-2010, 07:06 PM
redbull-1's Avatar
Check your PM.
Old 02-17-2010, 09:17 PM
vikki4567's Avatar
also i got it to start and no check engine light but as soon as u hit the gas everything like the lights in the dash cluster flicker and then the car will die and u can hear the relays clicking but if u get it started and put it in gear and hit the break and gas u can stall out and everything seems just fine have no idea what else to do any help thanks everyone Tyler
Old 02-18-2010, 11:18 AM
HonBeer's Avatar
Thats why you always disconnect the ground from the battery when working on the car.
Its an an amateur mistake.
Old 02-18-2010, 11:27 AM
He knows where you live!
TheMuffinMan's Avatar
Super helpful post bro!
OP,
Have you since tested the alternator to verify it's actually working still? Should be ~14V across the battery terminals while running.
Old 02-18-2010, 11:32 AM
ilikehonda's Avatar
have you checked to see if the dizzy is ok?
Old 02-21-2010, 06:23 PM
vikki4567's Avatar
ok it was one of my grounds finger tight thanks everyone
Muydos
06-03-2012 02:01 PM
johhnyu2
04-01-2008 11:38 AM
ss07
03-21-2007 07:49 PM
hamburgler
09-16-2005 03:40 AM
DSMDude
11-24-2004 04:24 AM
Quick Reply: 1997 Honda Accord Electrical Problem????
