1995 Honda Accord Trying to take out Harmonic Bolt
Old 11-16-2011, 09:33 AM
Tonychoi24's Avatar
Default 1995 Honda Accord Trying to take out Harmonic Bolt
Hello, I'm trying to replace my timing belt because it broke and I'm having a very hard time trying to take out a Harmonic Balance for some reason my friends and i can't take it out. What is the best tools to use to take off the harmonic? And just making sure do i turn it clock wise or counter clock wise?
Old 11-16-2011, 09:34 AM
Tonychoi24's Avatar
Default Re: 1995 Honda Accord Trying to take out Harmonic Bolt
Oh and it seems like we need a strong and powerful tools.
Old 11-16-2011, 11:44 AM
bdmlilburn's Avatar
check out the video in the faq on removing the honda crank pulley bolt
Old 11-16-2011, 08:37 PM
nus_dogg's Avatar
Counterclockwise on F22Bx 4cyl.
Old 11-17-2011, 04:20 AM
Thumper74's Avatar
Counterclockwise... You have the pulley holder, right?
Old 11-17-2011, 05:29 AM
H-T Order of Merit
TouringAccord's Avatar
Originally Posted by TouringAccord
Step 10
Remove the crankshaft pulley bolt and the crankshaft pulley. In the following pictures you can see how we did it, we’ve done it this way a few times now and it’s worked great.
Tools Used:
- Crankshaft Pulley holding tool by Schley Products, bought at TheToolWarehouse.
(Update: the Schley Products 60100 tool is no longer available and has been redesigned, so I updated the link to the redesigned tool.)
- 1/2” drive ratchet connected to the pulley holding tool.
- 1/2” drive 19mm 6point socket.
- 1/2” drive 20” long extension bar.
- 1/2” drive 18” long breaker bar.
- 2 steel pipes. 1 about 5’ long and the other about 18” long.
I've used the above method multiple times now, all with success.
And it's already been stated but the thread is a standard thread, meaning to loosen it you would turn it counter-clockwise.
and in case you haven't seen it already, check out this write-up on changing the timing belt...
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-timing-belt-timing-balancer-belt-water-pump-f22b1-1908944/
iponnet
02-24-2011 04:36 AM
Leo330
08-29-2007 07:35 PM
Yolandita
05-21-2006 06:54 PM
sackdinthehouse
10-04-2002 12:20 AM
jdmbike
02-20-2002 09:19 AM
Quick Reply: 1995 Honda Accord Trying to take out Harmonic Bolt
