1993 Honda Accord Charging Problem
The other day, I went to start the car, it was dead. I had the battery checked. It failed. I replaced it. A few days later the car just stalled out when driving. I was able to get the car home and charge the battery. I had the alternator checked. It failed. I replaced it. The next day it stalled out again. I took the battery out and had it checked. It checked out ok, but only had a 4% charge. It took the battery home and charged it over night. I put the battery back in the car. It started. I took it to the store where I purchased the alternator. They checked the battery and alternator. Both checked out. It belt is not lose on the alternator. I do not know where to go from here. Any ideas would be appreciated.
Re: 1993 Honda Accord Charging Problem
May i suggest you check your terminals that are not dirty and/or are loose, also check your ground. My cb was doing the same and it turned out to be bad ground cable.
laneysteele
03-10-2016 01:21 PM
jdm5ghb
01-10-2004 06:09 PM
