My beater Keep on drain out of battery
Old 10-25-2002, 05:57 PM
iam7head's Avatar
Default My beater Keep on drain out of battery
Like the title say. The 13 year's old beater kept on drain out battery.
especially when it's cold or raining(like today). I got the battery last year
and It failed me three times already.
how long your battery last?
Old 10-27-2002, 07:48 AM
jweller's Avatar
Default Re: My beater Keep on drain out of battery (iam7head)
Id check for a bad ground or soem kind of short in the system. sounds like something is slowly dicharging the battery.
the other thing you can do is buy a battery disconnect switch. looks like this
you just unscrew the green **** and the battery is disconnected from the car. takes a minute to screw it back in. my dad has one on his classic benz. he only drives it when its perfect weather, so it tends to sit a lot. used to have a lot of the same problems as you are having until he got this.
oh yeah, you can get it at http://www.eastwoodcompany.com
Old 10-27-2002, 08:41 AM
4doorH22's Avatar
Did you replace the battery 3 times in a year (i.e. 3 different batteries), or is it the same battery that's gone dead 3 times in a year. If it's the latter, then you probably just got a lemon battery.
Old 10-27-2002, 09:09 AM
iam7head's Avatar
Default Re: My beater Keep on drain out of battery (4doorH22)
auto zone recharged the battery for me..like couple of time.
the battery is good, but i am gonna check the alt. after i install the
header for my accord...
Old 10-27-2002, 10:15 AM
The_In_Kid's Avatar
don't forget to check for corrosion in the alternator plug
i keep reminding people this and sometimes its the problem
Old 10-27-2002, 11:19 AM
juicedh22's Avatar
Could you possibly be having alternator problems, and not battery problems?
[Modified by juicedh22, 3:19 PM 10/27/2002]
Old 10-27-2002, 05:32 PM
iam7head's Avatar
Default Re: My beater Keep on drain out of battery (juicedh22)
Yeah! because I just added water and recharged that sh_T!!!!!!!!
jk
thank for asking tho'
Old 10-27-2002, 05:34 PM
B2FiNiTY's Avatar
Check your alternator.
Old 10-27-2002, 05:35 PM
iam7head's Avatar
Default Re: My beater Keep on drain out of battery (B2FiNiTY)
is getting replace tomorrow and thank to all for being supportive..
Old 10-28-2002, 05:17 AM
Stew Pidasso's Avatar
Keep in mind that once you discharge a battery to where it is dead, that battery will only hold 60% of it's original charge. When it's cold that will be much less. If you kill a battery it is never the same...(unless it's a deep cycle battery)
Carol Martin
Honda Civic (2006 - 2015)
03-28-2019 06:04 AM
patrickstar
Audio / Security / Video
07-15-2009 04:38 PM
EGh22aEG
04-19-2002 12:05 PM
Quick Reply: My beater Keep on drain out of battery
