Wierd coolant overflow issue
Old 07-09-2006, 06:54 PM
dunkd's Avatar
Default Wierd coolant overflow issue
After driving around for awhile in any fashion (beating on it or just cruising, highway or city), my coolant overflow bottle will fill up a little bit. It will never fill up all the way, just stays at a certain spot. Even after cruising @ 4,000 rpms for an hour it will only go to that specific level. After driving and letting it cool down I can pour whats in the overflow bottle back into the radiator and the resevoir will be at the same level as when I first started driving, and the radiator will be topped off.
It has been like this since I put the motor together 500 miles ago and hasnt changed at all. There are no other symptoms that would lead to the likely suspect of a leaky headgasket. It also doesnt not use any coolant, just displaces a little into the overflow.
The radiator cap is a Stant brand and is new. The radiator is an aluminum PWR. What could cause this? When I pop off the radiator cap after letting it sit overnight there will be a strong suction sound.
I am not 100% knowlegable on how the radiator cap works, could it be faulty not allowing the radiator to suck in the coolant from the overflow?
Old 07-09-2006, 06:56 PM
Who is Mr Robot?
wantboost's Avatar
Default Re: Wierd coolant overflow issue (dunkd)
sounds like you might still have air in the system
Old 07-09-2006, 06:58 PM
dunkd's Avatar
Default Re: Wierd coolant overflow issue (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">sounds like you might still have air in the system</TD></TR></TABLE>
I've bled it by jacking up the front end and letting the car run until it starts coming out. I will try it a few more times though.
Also the coolant needle never moves after the car warms up.
Old 07-09-2006, 06:59 PM
Who is Mr Robot?
wantboost's Avatar
try checking the thermostat as well.
when mine went bad i had a similar problem
Old 07-09-2006, 07:02 PM
N20civicB18's Avatar
you have head studs?
Old 07-09-2006, 07:03 PM
dunkd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">try checking the thermostat as well.
when mine went bad i had a similar problem</TD></TR></TABLE>
The thermostat was replaced with an autozone one when the motor was rebuilt, so it only has 500 miles on it as well. But coulda been faulty since day one I guess.
Golden Eagle headstuds.
Old 07-11-2006, 05:23 PM
dunkd's Avatar
anymore ideas?
Old 07-11-2006, 06:18 PM
adseguy's Avatar
Default Re: (dunkd)
My .02 When bleeding the system.....squeeze and shake the hoses. I seem to free up a lot of air when I got that tip.
Old 07-11-2006, 06:37 PM
Topdawgg's Avatar
mine does the same thing.....
Old 07-11-2006, 07:53 PM
b00steds0l's Avatar
dumb question: the overflow hose is completely submerged in the bottle obviously...?
Old 07-11-2006, 08:06 PM
dunkd's Avatar
Default Re: (b00steds0l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00steds0l &raquo;</TD></TR><TR><TD CLASS="quote">dumb question: the overflow hose is completely submerged in the bottle obviously...?</TD></TR></TABLE>
uh yah, and mounted in oem location
Old 07-11-2006, 10:36 PM
turbotime's Avatar
i would say its the headgasket....
had the same problem on my last build and kept denying it was the headgasket until finally i ran out of options and replaced the gasket out of spite, ended up fixing my problem....
I would guess your leak is small now and may or may not increase... what kind of gasket are you using now?
Old 07-12-2006, 02:54 PM
Rikter's Avatar
I work at honda. checked with techs. Completely normal. That's what the bottle is there for.
-Rik
Old 07-12-2006, 07:15 PM
dunkd's Avatar
Its an OEM gasket bored to 84MM by Golden Eagle.
crxaddikt
03-25-2014 11:00 PM
civicsir94
05-20-2008 03:21 AM
89sparks
05-14-2008 07:38 AM
ALLMOTORD16Z6
05-20-2005 03:27 AM
Quick Reply: Wierd coolant overflow issue
