Used piston rings??? SHould I USe them ?
Old 01-09-2005, 12:12 AM
cueballsi's Avatar
Default Used piston rings??? SHould I USe them ?
Used piston rings??? Is it possible to re-use them?????? how do u know if the are still useable?
Old 01-09-2005, 02:09 AM
W O T's Avatar
Default Re: Used piston rings??? SHould I USe them ? (cueballsi)
Why gamble having to tear apart the motor over $80?
bearings, rings should always be replaced when rebuilding/tearing down a motor
Just work 1 overtime shift or ask mommy to cover the cost so you dont have to mess the driveway
Old 01-09-2005, 05:09 AM
USDM 4G VTEC's Avatar
rings are $65
and once they are out, they never seal good again
dont go cheap and get new ones
Modified by USDM 4G VTEC at 7:48 PM 1/9/2005
Old 01-09-2005, 06:54 AM
Rod.'s Avatar
Default Re: (USDM 4G VTEC)
used internals = no no no
Old 01-09-2005, 07:10 AM
velocitytrends's Avatar
NO!
Old 01-09-2005, 07:42 AM
speedworks's Avatar
Default Re: (velocitytrends)
never reuse piston rings, unless u have a bad mosquito problem that needs taken care of.
Old 01-09-2005, 08:11 AM
sh!t happens.
G
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by velocitytrends &raquo;</TD></TR><TR><TD CLASS="quote">NO!</TD></TR></TABLE>
Old 01-09-2005, 08:53 AM
cnydc2's Avatar
Default Re: (G"UNIT)
New rings and bearings are cheap. I am going to have to go with everyone else on this one, GO NEW
Old 01-09-2005, 10:03 AM
AsianMullet's Avatar
Default Re: (cnydc2)
i dont think i'd even use used pistons again.
Old 01-09-2005, 11:50 AM
cueballsi's Avatar
Default Re: (EKchump)
thasnk for th heads up.. i may just sell it all ( eagle rods wtith srp;s) ..... i found a used set od crower rods and maybe i;ll get soem cp pistons..... there goes a budget build at least i will get reliablity and piece of mind
Old 01-09-2005, 01:56 PM
Flr Power's Avatar
Default Re: (cueballsi)
You can always reuse rings, pistons and bearings if they go back in the same engine. But measure everything. You still have to measure when you buy new parts.
Old 01-09-2005, 02:15 PM
incredteg3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EKchump &raquo;</TD></TR><TR><TD CLASS="quote">i dont think i'd even use used pistons again. </TD></TR></TABLE>
umm you have never bought 400$ pistons then i guess.
your funny
Old 01-09-2005, 02:32 PM
cnydc2's Avatar
Default Re: (incredteg3)
reusing pistons and rods are no problem, as long as they are still in spec and have the proper clearances. I wouldn't jump to the conclusion of selling everything you got to get something different unless you absolutly want too. If you are trying to do a budget build up just stick with what you got and get some new bearings from Honda and some new rings from JE/SRP.
Boyle.R
06-21-2014 12:38 AM
92civichbor
10
08-05-2008 11:09 AM
DHARRIS1562
12-13-2007 04:50 PM
rocket_R
06-13-2006 11:11 PM
rocket_R
06-13-2006 11:09 PM
Quick Reply: Used piston rings??? SHould I USe them ?
