Turbo Selection Options: B16/Spoon Cross-mission Trans for Flat Torqueband
#326
Re: Turbo Selection Options: B16/Spoon Cross-mission Trans for Flat Torqueband
b16's stopped being produced 17 years ago, finding one in perfect condition with original bore is a longshot. Maybe just buy new pistons?
HMO would probally be best bet, but for that price you could sleeve your block
Edit: oops I already told u this
#327
my block is junk at this point. So does anyone know of a reputable source to get a block from that isn't eBay or craigslist? Two of the shops around here came up with nothing.
#328
Anyone else have any ideas on where to get a block?
Arias said the pistons are fine and they are going to clean them up and get me new rings but i have no block. I have called a few places to see about fixing the line hone on the engine i have but two of the shops locally that can do it are 6-8wks out. Any help on finding a block would be great!!
#329
HMO or any importer around you. but they most likely wont just sell a block.
#330
UPDATE:
Pistons checked out fine by arias and I have the back with a new polish, rings and spirol locks.
I also have a good engine block. The shop said the line hone was good but the bores were .020 over so they are going to re-sleeve it and bore it to spec. It should be done this week
So now i just need to pick up a ring compressor, ring filer, bearings and plastigage.
Question though.... should i just order a set of main and rod end bearings from ACL and just swap out the ones that are out of spec with the right OEM color or is there a better way to do it??
#332
#333
It really depends. I mean my rods and mains were from 0.0015 to 0.0018 and I thought it was acceptable. Bottom end still rocking at 600whp 5 years later . Build it on the loose side IMO (Type R specs are close to what I ended up with)
#334
ok but I would still need to order a full set and change the ones that are out of spec (if any) correct??
#335
ok but I would still need to order a full set and change the ones that are out of spec (if any) correct?? If that's the case I will order full sets and go from there.
#337
#338
I think it's generally agreed that plastigauge is not considered a primary method of checking clearances. My opinion is that it's cheaper to buy the right tool than rebuild the engine. I'm sure, especially with your engine experiences, you would agree. With all due respect if you don't have the tools or skills to do it right pay someone who can.
#339
You beat me to it already. Yeah, went ahead and measured everything in my climate controlled clean room on this other block to the .00000 place (seriously). I then realized i cannot get +.25 bearings from honda. kind of a moot point.
#340
Any real benefit in running the type r or ACL oil pump??
http://realstreetperformance.com/Shop-by-Engine/Oil-Pumps_3/
#342
I got most of the engine assembled this weekend. Everything fell right into spec so hopefully this one last longer then the others. I was getting between .0015 and .0018 with the dial bore gage and the plasti-gage agreed. Now i just need to torque the head down, install the cams and intake/exhaust parts.
#344
#345
did you end up going with an ACL pump?
just curious I was waiting for others to respond as the general consensus on that is OEM will work fine.
I actually have a somewhat aftermarket pump which is basically a glorified OEM pump that has been ported and most likely shimmed I also gasket matched the port on the block itself. Its been working just fine for me im sure a completely OEM pump would work just as well, but cant complain Cold starts is around 85 PSI before Oil squirter delete
Apocalypse Racing Import Techs | Motor swaps
#346
I just used a stock pump. No one said anything. The pump you have looks interesting though.
I also looked at switching to a 4qrt or 5 qrt moroso oil pan instead of my baffled one but lots say they leak. Not sure if it will be better than what I have or not.
#347
Ahh Ive seen shodan down talk my pump on california dads thread so you should feel fine with OEM, again havent had issues with my pump either it seemed pretty quality to me it is a reworked OEM pump.
I think all oil pans leak unless you install the gasket just right, been using the myhondahabbit gasket and no leaks with my oem pan, personally I would rather have an OEM pan with the Password JDM baffle kit which i beleive is what you are using
#348
I dont see any advantage to moroso pan. Drain is in a crappy location and they dont quite fit as good as oem.
#349
yeah i am just looking for piece of mind with the oil pump and oil pan.
I just looked at the cams they have some scoring on the journals so those will need to be reworked. Any issue with using the cams out of the b18 if they are in good shape?
#350
gsr cams are an upgrade from b16 cams, itr or ctr cams are even better you want ones from 00-01 year I believe, but they can be hard to find. Just grab a set of gsr cams, easy to find and cheap.
