turbo newbie : need advice
like the topic says im new to the turbo thang. i traded my allmotor setup for a t3 turbo kit. everything is done but it won't boost past 3lbs then it seems once its put out boost the engine starts to sputter. code 3 (map senson) i'll fix that but why only 3 lbs? leaks? i don't believe the the vaccume because the idle is superb. the setup is a ls/vtec, stock bottomend, pnp b16 head, stock injectors, stock fuel system, vortech fmu, vafc soon to come out in favor of hondata. help please.
Modified by B20vtec81 at 11:41 AM 6/25/2004
Re: turbo newbie : need advice (98B00STED)
no its all complete. and i have 3 check valves to bleed the pressure. how much boost can i plan on boostin the way its? and be safe. actually i have a cheap *** delta wg (7lbs) but i heard it kreeps to 10.
Re: (z6)
get rid of that waste gate its crap lol and see what happens, i say skip the missing link and just get injectors and have a local shop tune ur ecu for u, what type of fuel management are u running?
Re: (allablur)
alright people make mistakes when they type..................... (z6) why the **** would you put in your stupid *** coment. "there is no such thing as a ls vtec bottomend." I KNOW THAT STUPID ***!!! so you jump on this thread to state that stupid point? its kats like you that make me sick. look man im tring to learn some **** i don't already know so please take those lil kid *** comments elsewhere.
Re: (z6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by z6 »</TD></TR><TR><TD CLASS="quote">there's no such thing as a stock ls/vtec bottom end</TD></TR></TABLE>
Why not? Its an LS bottom end. What isn't stock about and LS bottom end?
Re: (MachAF)
Check off the dumb idiotic almost forgotten things first.
Are the check valves installed properly. I cant suggest any tips since I didnt go the check valve/missing link and FMU setup. I chose to go with the hack. Obviously from the code you are throwing, something is wrong in that area.
Re: (specv5150)
can somebody fill me in what a missing link is please? maybe that can be the answer to my **** boosting above 3lbs. btw headgasket didn't hold a seal so i have to change it out also. after runnin the car today temp was lifting and dropping. after i got home a shut it down i can hear a sssssssssssssss sound whissling under my distributor.
Re: turbo newbie : need advice (B20vtec81)
did you do a comp. test & a leak down test?
and look at your wastgate and bov see if there doing there job right
your going to need more fuel bigger injectors would help and you have to get some kind of vafc or afc being to lean is not good
Re: turbo newbie : need advice (Frankinfreak300)
i do have the missing link on there. i thought that was called a check valve.
what do i look for when checking the bov and waste gate? im currently runnin a vafc on it. i have the fuel turned up to +9 across the board because when i runnin my hi comp b20 bottemend he said that with obd0 you can only go up to +9 with throwing a 3 or 5 code. so thats where i set it. but i have honda S200BN that's going on next month.
when i get it all the bugs out, without injectors and hondata can i run around 7lbs the way it sits. and where should i have my timing set? i don't wanna get tuned until until i have my hondata in and the engine broke-in. it only has like 30 miles on it.
4dr*sleeper
08-16-2005 12:33 AM
