Turbo CRX half radiator issues resolved!
Old 05-17-2006, 06:32 PM
ham
ham's Avatar
Default Turbo CRX half radiator issues resolved!
This was the original problem... no room for a full radiator and hardly any for a 1/2 size because of the wastegate location.
EG radiator, GANSTER LEAN, overheated all the time... had to go.
upgraded to the fluidyne "CRX 1/2 size" radiator. Hoped it would fit. Turned out to be the EG radiator with a different part number GANGSTER LEAN, ran very warm 220+ all the time, had to go.
I pulled everything off, cut out the headlight frame a little and pounded in the side, cut the **** out of the hood, made up that nice elbow to relocate the WG, made a new dump tube.
still some cleaning up to do
im making a bracket tomorrow to fasten the radiator (no more zip ties)
hood closes runs perfect, stays nice and cool
13psi on a totally bone stock b18c.
SC61 52E this one: http://www.slowboyracing.com/more.php?id=2221
ready to ROWL
Modified by ham at 10:55 PM 5/17/2006
Old 05-17-2006, 06:47 PM
Pay2play killa's Avatar
Default Re: Turbo CRX half radiator issues resolved! (ham)
or you could have made some JGTC baffles like I did to keep hot air from around the turbo from going through the rad
good deal though; i may have to try that instead of the jgtc stuff
Old 05-17-2006, 06:54 PM
ham
ham's Avatar
Default Re: Turbo CRX half radiator issues resolved! (Pay2play killa)
i hated the ganster lean. its so much better having the air actually flow THROUGH the radiator. GL with your setup though.
Old 05-17-2006, 07:00 PM
SuperSi's Avatar
good ****
Old 05-17-2006, 09:07 PM
speeddave's Avatar
Default Re: Turbo CRX half radiator issues resolved! (SuperSi)
looks good ham, hey i remember a while back you had rubbing issue's with your lenso's... what did you end up doing to remedy it? spacers?
Old 05-17-2006, 09:20 PM
Brrraaaap!
Blaze45's Avatar
Default Re: Turbo CRX half radiator issues resolved! (speeddave)
I hacked the crap out of my CRX to make the EG rad fit too. Accpet, the single core aluminum rad sucks and I can make my car over heat easily in this weather. The dual core copper unit cooled much better then the single alum one Im running. Id up grade to a fluidyne one accpet from what you have mentioned temp wise, I wouldnt be much better off...
Oh the trials of tyring to keep a boosted EF cool in the summer...
Blaze
Old 05-18-2006, 02:32 AM
HamiltonRex's Avatar
Default Re: Turbo CRX half radiator issues resolved! (Blaze45)
Im running hot too... 220+, and i made some ducting last night to go aro und the edges/bottom/top of my rad (my rad is on a twisted angle, not leaned back) so hopefully it will help build up air pressure on the rad instead of flowing around it
Old 05-18-2006, 03:29 AM
ham
ham's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speeddave &raquo;</TD></TR><TR><TD CLASS="quote">looks good ham, hey i remember a while back you had rubbing issue's with your lenso's... what did you end up doing to remedy it? spacers?</TD></TR></TABLE>
i got arp extended wheel studs and had my brother (laser machinist) cut me some SS 10mm wheel spacers. I also got some bfg drag radials for the street
Old 05-18-2006, 05:12 AM
drintegra's Avatar
nice setup, what mani is that. ALso did you not have room ro mount the radiator behind the front facia? Or mount it in an angle closer to the head light?
Nice car though
Old 05-18-2006, 07:48 AM
streetrage's Avatar
Nice car, it reminds me of my baby! (see avatar)
Alex
Old 05-18-2006, 07:52 AM
HondaCivicSiR1's Avatar
Default Re: Turbo CRX half radiator issues resolved! (drintegra)
are you using traction bars? i have a very simular set up to in my ef hatch but no turbo anyways if you don't mind i'll post some pics of mine to show how i used a eg half size radiator and didn't have cut the hood
Old 05-18-2006, 08:17 AM
MikeySpec's Avatar
Default Re: Turbo CRX half radiator issues resolved! (HondaCivicSiR1)
It looks as if an innovative mounts or full-race front xmember might've helped.
Old 05-18-2006, 08:23 AM
Mugencrxsir1's Avatar
Default Re: Turbo CRX half radiator issues resolved! (MikeySpec)
Nice ride bro, but use some engine degreaser on the engine bay, or paint the engine bay black. I little bit of elbow grease and that baby will shine!!!!!!!!!
Old 05-18-2006, 08:24 AM
ham
ham's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeySpec &raquo;</TD></TR><TR><TD CLASS="quote">It looks as if an innovative mounts or full-race front xmember might've helped.</TD></TR></TABLE>
I have hasports and z10 bars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drintegra &raquo;</TD></TR><TR><TD CLASS="quote">nice setup, what mani is that. ALso did you not have room ro mount the radiator behind the front facia? Or mount it in an angle closer to the head light?
Nice car though </TD></TR></TABLE>
Its a custom manifold made for an EG / teg. Cant mount the rad at an angle or air will not flow through it, that was the reason for doing all of this. The radiator is 2" too tall.
Old 05-18-2006, 08:26 AM
Default Re: Turbo CRX half radiator issues resolved! (Mugencrxsir1)
And how do you like your turbosmart WG? And what size?
Old 05-18-2006, 01:45 PM
ham
ham's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">And how do you like your turbosmart WG? And what size? </TD></TR></TABLE>
its a 38mm turbosmart, IMO its better than a tial. with the same setup, the tial WG opened a little early then creeped up to the right boost, i didnt like that. the turbosmart is instant and extremely consistent. i believe its part of the reason it hasnt blown up yet, the boost and afrs are consistent.
Old 05-18-2006, 01:46 PM
ham
ham's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugencrxsir1 &raquo;</TD></TR><TR><TD CLASS="quote">Nice ride bro, but use some engine degreaser on the engine bay, or paint the engine bay black. I little bit of elbow grease and that baby will shine!!!!!!!!! </TD></TR></TABLE>
its been an ongoing project, i havent washed it since last fall. when i do it will be lookin cleaannnnnn
smash fascism
07-14-2008 05:16 AM
office888
16
12-05-2006 05:10 PM
DC_RaceR
11-29-2005 12:38 PM
BoostdRex
34
08-15-2005 08:15 AM
Quick Reply: Turbo CRX half radiator issues resolved!
