Tuning a nitrous engine... optimal Air Fuel Ratio
Old 11-02-2005, 07:17 PM
B16Drag's Avatar
Default Tuning a nitrous engine... optimal Air Fuel Ratio
Does anyone know what the optimal Air Fuel ratio when tuning a nitrous engine? I know turbo is ~11.5-12:1 but what is the AFR for a nitrous tuned engine?
I know some of you guys have tuned nitrous fed engines. Thanks.
Old 11-02-2005, 07:39 PM
mrbsponge's Avatar
i tuned my nitrous motor to a 12.5:1 it just seemed to like it there more than either which way i went with jetting or fuel added thru the ecu.
if youre in the 12s you are definetley safe, work your way from there, i do however suggest an EGT gauge when tuning nitrous as well, but i dont like to use it on my turbo car
Old 11-02-2005, 07:40 PM
B16Drag's Avatar
yes using an EGT along with the other gauges as well. I guess I'll just stick with the 12:1 AFR. anyone else got any ingenius inputs?
dschenke
Engine Management and Tuning
01-25-2009 05:10 PM
Sr420Det
02-29-2008 08:09 PM
90crxlst
10-02-2005 05:46 PM
RI_TM
02-23-2005 02:33 AM
freakie
05-16-2002 10:38 PM
Quick Reply: Tuning a nitrous engine... optimal Air Fuel Ratio
