torque specs for eagle rod bolts?
i bought some eagle rods used and i need to know the torque specs for the rod bolts.. i am assuming they are the regular rod bolts that come with eagle rods when you buy them from eagle and not the upgraded ARP ones..
Re: torque specs for eagle rod bolts? (b18bturbo)
if its b18c1 then like your sig
The correct torque specs for Eagle rods on a B18C1 is 28 ft. lbs. using the ARP moly lube. You should use nothing but this lube for correct torque. Over-torquing the bolt will weaken it causing failure.
Re: torque specs for eagle rod bolts? (nextelbuddy)
I'd stick to the 28 - just did them last night as a matter fact. Couldn't find the thread where a supposed Eagle employee stressed 28lbs - not 29, not 27.
FYI, these were with Arp 2000 bolts using the supplied moly lube for H22 rods.
well i dont have any LUBE since i bought my rods used they didnt come with any and im having my block assembled thiw weekend which leaves me no time to order any from eagle
