is the stroke from an LS same as in B20?
Old 06-11-2009, 06:55 AM
I'm not Rick!
rick_rabies's Avatar
Default is the stroke from an LS same as in B20?
The LS I know has more stroke than a b18c. (torque) the b20 has more displacement...but does the b20 also have the same stroke as the LS or the shorter stroke like the b18c? the reason why I ask is because. I need to decide on what block to find. Bore, sleeve and find pistons for.i want to get the biggest bore and most stroke out of a B series for turbo without doing a block extension
Old 06-11-2009, 07:02 AM
kyden's Avatar
Default Re: is the stroke from an LS same as in B20?
b20 cranks are the same as ls. only difference in the blocks is bore and sleeve material.
Old 06-11-2009, 07:05 AM
I'm not Rick!
sweet so sleeve a b20 and im set?
Old 06-11-2009, 07:06 AM
BlakeJ53's Avatar
LS/ B20 Cranks = 89mm
GSR/B18C1 = 87mm
Old 06-11-2009, 07:08 AM
CerealKiller's Avatar
...or sleeve an LS to 84.mm.
Old 06-11-2009, 07:28 AM
I'm not Rick!
cant i bore out a b20 to 2.2L? and sleeve that?
Old 06-11-2009, 07:34 AM
kyden's Avatar
no, there's not enough cylinder wall.
Old 06-11-2009, 07:37 AM
I'm not Rick!
hmmm. LSs are a dime a dozen here..almost free, any preferrence on an LS block when doing this for turbo b18B or A?
ExospeedAMcrx's Avatar
B18AB block 84mm bore, 89mm LS/B20 crank. about 2.0L Done!
Thats all you need for a turbo setup. Don't make it any more complicated.
B18A/B all the same.
Old 06-11-2009, 12:35 PM
Silva Bullit DC4's Avatar
Originally Posted by CerealKiller
...sleeve an LS to 84.mm.
OP, here's your answer. 2.0L of displacement should be plenty.
/thread.
More importantly...what are your power goals, and plans for the car?
Old 06-11-2009, 12:46 PM
I'm not Rick!
i have a gsr bottom end now with about 350 on 10lbs. i would like at least 600hp. and do 10s. and i would like to try 25lbs but on a bottom end with alot of potential. and id rather not mess with the b18c bottom end cuz il keep it for a back up.
that way i wont street drive it like an idiot id just park it in the garage until i go to the track.
Old 06-11-2009, 01:05 PM
HT White Ops
SD_Lurker's Avatar
Get an LS block. Most sleeve manufactures prefer not to sleeve B20 blocks. GE will do it but prefer to sleeve LS's.
Old 06-11-2009, 07:06 PM
I'm not Rick!
sweet thanx. i can get an LS tonight for free. woooot
b20veghathc
12
10-05-2010 07:16 AM
xism
01-10-2007 05:47 AM
civdx94
08-06-2005 08:12 AM
Quick Reply: is the stroke from an LS same as in B20?
