Stripped oil jet threads? Please HELP!
Old 04-03-2008, 07:50 PM
totsie7944's Avatar
Default Stripped oil jet threads? Please HELP!
Ok so my builder put together the block without the oil jets installed....so tonight I went to try and install them while the motor is on a engine stand and I was on my back under the motor. I got 2 in ok, but the other two I thought were threading and I went in the first few (maybe 3-4 threads) and then felt it getting tight too fast.
I backed out the bolts and the threads were definately cross threading...now I have NO idea what to do. I can't believe a experienced builder wouldn't have thought of this. What can I do? I might try a thread chaser but I am not sure this is going to work at this point. What happens if no oil jets are there and the hole is left wide open?
Old 04-03-2008, 08:37 PM
* B A N N E D *
count me out's Avatar
Default Re: Stripped oil jet threads? Please HELP! (totsie7944)
just tap it with the same thread, then chase it. should be fine.
Old 04-03-2008, 08:46 PM
totsie7944's Avatar
Default Re: Stripped oil jet threads? Please HELP! (count me out)
hmm I guess. But with the crank in there its hard to get the 100% right angle...
Old 04-03-2008, 08:51 PM
Boner_Ben's Avatar
You cant leave the hole open, you could plug the holes and not run the oil squirters.
Old 04-03-2008, 09:03 PM
Moderator in Chief
Muckman's Avatar
Why the hell were you on your back if its on an engine stand?
Old 04-03-2008, 09:08 PM
totsie7944's Avatar
Default Re: Stripped oil jet threads? Please HELP! (Boner_Ben)
how will I plug them if the threads are messed up?
I was on my back because it I turned the motor upside down it would be harder to keep the bolts inthe socket without falling out?
* B A N N E D *
wow.
Old 04-04-2008, 05:02 AM
totsie7944's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by count me out &raquo;</TD></TR><TR><TD CLASS="quote">wow.</TD></TR></TABLE>
Helpful..
pjr710
06-03-2008 03:45 AM
totsie7944
04-04-2008 07:01 AM
totsie7944
04-03-2008 08:27 PM
Buktheng
08-31-2007 05:05 PM
Kevm30
Honda Civic (2006 - 2015)
16
11-17-2006 11:54 AM
Quick Reply: Stripped oil jet threads? Please HELP!
