resistor box mis-install... could use some help
Old 12-20-2003, 11:49 AM
RedStarGsr's Avatar
Default resistor box mis-install... could use some help
hey guys, well in the heat of the moment i messed up installing my resistor box...i think. I used this picture and didn't check the actual wires to see if they went to the injcetors and now it is whining up and down at around 1500-2000 if it even kicks over at all ( have to give it gas ). skip the 'yer a tard' talk and help me out.
WHAT I AM ASKING is where do each one of these 7 wires going. there are 7 wires on my harness (for my 1992 integra gsr...obd1) and i used the rightest four wires... obviously thats wrong. i checked hondata's site and just got more confused. What i need to do now is rewire the wires which aren't the injectors back to stock, and the injector wires to the box. so if anyone has done any research and knows exactly where these 7 wires go, it would greatly help me out. Thanks.
credits to ladysman for the pic...
this doesn't help, but here is where i stand as of now...
once again, thanks for your help. seeya.
Old 12-20-2003, 03:08 PM
B A N N E D
VNTEC's Avatar
Default Re: resistor box mis-install... could use some help (RedStarGsr)
Here dan, hope this helps
The resistor box has 4 black wires and one red wire. After cutting the black and yellow wires solder each of the black wires from the resistor box to each of the black and yellow wire that leads to the injectors, it does not matter which black wire in the resistor box goes to which injector. Be sure the black and yellow wires you find are actually the injector wires by checking for continuity on the injector connector. Now we need to connect the red wire from the resistor box to all 4 of the other black and yellow wires. It is best to use a butt connector to do this, if you try to solder all these wires together you will end up with a large ball of solder. See the wiring diagram below for using the resistor box.
Old 12-20-2003, 04:53 PM
XxslayerxX's Avatar
Default Re: resistor box mis-install... could use some help (VNTEC)
you need to test for resistance in the wires. That's the only way you can find out unless you know someone with your model.
Old 12-21-2003, 01:19 AM
IntegracinGSR's Avatar
gotta check for continuity to see which ones go to the injector.. the ones that have continuity and light up the meter, each one of those wires ( the ones from the injectors ) has to connect to its own black wire ( from the resistor box ) .. and then the remaining three wires ( the black and yellow ones that also come from the injector but dont have continuity ) all must be connected to the red wire ( from the resistor box )
Old 12-21-2003, 08:48 PM
RedStarGsr's Avatar
thanks for your help guys...if you guys have any pictures or any more diagrams they couldnt hurt. im going to attemtp to fix what ive already screwed up.
Old 12-21-2003, 10:00 PM
Dee
Dee's Avatar
Default Re: (RedStarGsr)
https://honda-tech.com/zerothread?id=517274
Old 12-21-2003, 10:07 PM
New User
simple4012's Avatar
Default Re: (Dee)
you really only need to tap into one of the wires not all of them. they each have enough power for what needs to be done. no need to overload the circuit. that might lead to eld codes as well
Old 12-21-2003, 11:21 PM
just so no one gets confused and mis-installs it.. i think what Simple4012 means when he says you only need to tap into one of the wires, is that you only need to tap into one of the wires ( without continuity, this is the one that goes to the ecu ) to connect the red wire.. but each of the blacks need to be hooked up to its own injector wire which is black/yellow and has continuity..
kornkid21792
01-30-2010 06:04 PM
Nextelbuddy
06-12-2005 06:12 PM
Quick Reply: resistor box mis-install... could use some help
