replaced Hondata with EMS,, now my tach is all screwed up....
Old 04-10-2005, 01:28 PM
ATgrills.com's Avatar
Default replaced Hondata with EMS,, now my tach is all screwed up....
I changed my set up from JRSC to turbo,,, I use to have hondata 2b and my tach in my 01 type R was perfect and normal...
Now with EMS it goes crazy over 4500RPM,,, i dont know whats the problem???
I had a jumper harness with the hondata running a p28,, now i have the same jumper harness pluged directly in the EMS,,,,
The tach is fine at addle and driving .. but as soon as I go over 4500 rpm the tach like drops to 0 rpm then start going up and down,, then stays at 0,.,, and as soon as I go under 4500RPM the tach workes perfectly??
is this a ground problem or a electrical problem???
thanks
Tyler
Modified by ATgrills.com at 5:57 PM 4/10/2005
Old 04-10-2005, 04:18 PM
Default Re: replaced Hondata with EMS,, now my tach is all screwed up.... (ATgrills.com)
anyone???
Old 04-10-2005, 04:57 PM
please ... i need my tach to work
Old 04-10-2005, 05:39 PM
19sec beast's Avatar
I've got the same problem and I'm using Uberdata.
No idea why it does this, but would be nice to have an answer.
Old 04-10-2005, 07:10 PM
Default Re: replaced Hondata with EMS,, now my tach is all screwed up.... (19sec beast)
anyone have an idea?
Old 04-10-2005, 07:20 PM
done's Avatar
maybe a sensor??
i know my speedo does that, once the voltage gets up there, it goes crazy.
Old 04-10-2005, 07:23 PM
Default Re: replaced Hondata with EMS,, now my tach is all screwed up.... (Jordo)
what kind of sensor??? isint to do with the distributor???
i know it was fine in the other car,,, so im guessing a wiring problem.,,
but where?
Old 04-10-2005, 07:45 PM
Blown90hatcH's Avatar
On your conversion harness, verify that there is a wire that goes from OBD1 A21 to OBD2 A19/B13.
Jason
http://www.JKobd.com
Old 04-10-2005, 08:11 PM
Default Re: replaced Hondata with EMS,, now my tach is all screwed up.... (Blown90hatcH)
well i was using the same harness with my hondata and it was perfect.. so I dont think its that!
Old 04-10-2005, 09:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATgrills.com &raquo;</TD></TR><TR><TD CLASS="quote">well i was using the same harness with my hondata and it was perfect.. so I dont think its that!</TD></TR></TABLE>It's up to you if you want to solve your problem or not. I have seen this a few times on the AEM EMS system where there is an issue with these wires, but what ever you want to do.
Old 04-11-2005, 03:34 AM
well i would feel kinda gettho if my tach dosent work properly... ive invested way too much time and money in my car....
so you think its a wiring problem??
I know this happens if you put the wrong year cluster in the car... but i have an 01 with an 01 cluster! so I dont get it!
Old 04-11-2005, 06:01 AM
Drag_On's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ATgrills.com &raquo;</TD></TR><TR><TD CLASS="quote">well i would feel kinda gettho if my tach dosent work properly... ive invested way too much time and money in my car....
I know this happens if you put the wrong year cluster in the car... but i have an 01 with an 01 cluster! so I dont get it!</TD></TR></TABLE>
What he is saying is not to "leave it alone" but to take his advice and go check it. he posted a possible solotion and to go check it and you said "I'm using the same harness, thats not it"..
He responded by saying he has seen this before and you should check it out..
He was using TACT. Go check his advice
Old 04-11-2005, 07:40 PM
Default Re: replaced Hondata with EMS,, now my tach is all screwed up.... (Drag_On)
still not working
Old 04-11-2005, 08:08 PM
Try putting a 1k ohm resistor in between OBD1 A21 and OBD1 A25 on the conversion harness.
uNF$@#!
12
05-30-2009 04:37 PM
H22Luda720
10-16-2008 07:46 PM
SikITR01-248
05-25-2005 08:02 PM
mugenintegra16
01-31-2004 03:53 PM
JM Performance
06-21-2003 09:27 PM
Quick Reply: replaced Hondata with EMS,, now my tach is all screwed up....
