civic turbo problem please help me
Old 08-06-2008, 11:29 PM
arazeg6's Avatar
Default civic turbo problem please help me
hey guys i have civic hatchback turbo and when the car gets hot after flooring it when i drive it for 15 to 20 min the car turn off and it doest start for like 2 min the it starts right up again then when i floor it a gain it turns off or sometime just driving it normal i changed the blow off valve but no difference its a b20 block b16 head.if u guys know what would be the problem please help me and i changed the radiator its aluminum radiator now but not in the pic.
[img=http://www.host-images.com/u/files/fngxt95tx0yl67mhqzvv_thumb.jpg]
Modified by arazeg6 at 12:40 AM 8/7/2008
Old 08-07-2008, 12:35 AM
H-T White Ops
Frozen E's Avatar
Coil getting too hot and not sparking again until it cools off perhaps. Had a Lude that did that.
Old 08-07-2008, 10:24 AM
arazeg6's Avatar
Default Re: (IslandSi)
so what should i do now how should i fix that problem
Old 08-07-2008, 12:35 PM
riddlinkid1986's Avatar
Default Re: (arazeg6)
are you tuned? what is your a/f's? what plugs are you using? what size injectors...ect?
Old 08-07-2008, 12:49 PM
LSTEG96's Avatar
does it break up at all? kinda sounds like it could be the igniter and you are getting lucky with the restarts?
Old 08-07-2008, 01:47 PM
arazeg6's Avatar
Default Re: (riddlinkid1986)
its tuned im using 550 cc rc injectors after the tune the blow off valve broke i replaced it with a diff one
Old 08-08-2008, 07:29 AM
Speed94's Avatar
Had the same issue with my boosted Mustang...turns out the cap and rotor had to be replaced. It would get hot then shut off and not start again til it cooled off. Replaced it and all is fine
Old 08-08-2008, 04:48 PM
ghostskinner's Avatar
Default Re: (Speed94)
its the coil in the distributer going bad change it immediately before it dies on you
NumberB
04-18-2004 06:26 PM
lagingtorpe
03-18-2004 06:15 AM
FOrSfEd
02-05-2004 04:48 PM
andrekun
09-12-2001 08:31 AM
Quick Reply: civic turbo problem please help me
