Oil filter: which one to get?
Old 08-17-2005, 12:05 AM
Maxime's Avatar
Default Oil filter: which one to get?
So i've been using OEM Honda oil filter since I got the car 5 years ago.
But it seems the damn oil filter get's smaller and smaller everytime I buy a new one. I swear the last one I bought was barely the size of a soda can. The one I use on the 94 2.0L Golf is almost 4x bigger.
I was told by the dealer that all Hodna models use the same filter now. But that think looks really really small. Should I continue using the OEM filter or change to an aftermarket one?
Old 08-17-2005, 12:13 AM
Maxime's Avatar
Default Re: Oil filter: which one to get? (Maxime)
Did a new search and found this:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">You used to be able to get Honda filters either made by Filtech (USA) or Fram (Canada). Since Honda switched to the smaller size, I haven't seen Filtech. (Anybody??)
Honda 15400-P0H-305 = US Filtech, no longer available
Honda 15400-PT7-005 = Canada Fram, no longer available
Honda 15400-PCX-004 = Japan S2000 filter
BTW, Honda's smaller filters are now being labeled as 'Honeywell', since Honeywell owns Fram. But I'm not sure whether Fram/Honeywell uses the cardboard end-caps & otherwise cheap construction when they're making filters for Honda? Until someone cuts one apart, I guess it's possible they make Honda filters better than the ones under their own label??
Honda 15400-PLM-A02 = Honeywell, new smaller size
Guess I'll buy a S2000 filter. lol
Modified by Maxime at 5:29 AM 8/17/2005
Old 08-17-2005, 12:24 AM
Redline130's Avatar
Yeah, get the PCX filter.
Old 08-17-2005, 12:55 AM
OG triple OG
ATS*Mark's Avatar
Default Re: Oil filter: which one to get? (Redline130)
i run the s2k filter
Old 08-17-2005, 09:00 AM
Sprockets's Avatar
Default Re: Oil filter: which one to get? (Hella_JDM)
I have a good supply of the S2000 PCX filters. It's made in Japan by Toyo Roki. Also, you can use your old Honda filter wrench with this.
Old 08-17-2005, 09:08 AM
93LSivic's Avatar
Napa Gold for me and all my customers, unless they prefer other. Ive done a little homework.
Believe it or not.....
http://theoildrop.server101.co...m;f=6
Old 08-17-2005, 09:09 AM
Mohsin's Avatar
Default Re: Oil filter: which one to get? (93LSivic)
Hamp gets my vote , if not then OEM
Old 08-17-2005, 10:04 AM
tthame1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93LSivic &raquo;</TD></TR><TR><TD CLASS="quote">Napa Gold for me and all my customers, unless they prefer other. Ive done a little homework.
http://theoildrop.server101.co...m;f=6</TD></TR></TABLE>
Yep, Wix filters are great.
R_ACE1
06-16-2009 06:56 PM
EG8Master
17
09-30-2006 04:14 AM
tolowhb
04-25-2004 04:39 PM
SLeePeR012
12
11-08-2003 09:05 PM
Quick Reply: Oil filter: which one to get?
