No Spark but have fuel
Old 08-29-2005, 09:23 AM
98coupe's Avatar
Location: NOVA, but OC MD for the summers, 10th St., Tyson R.I.P, USA
Default No Spark but have fuel
Took out my LS turbo yesterday to warm it up and do a compression test. Pulled all wires off distributor and pulled one plug at a time hooked up gauge and cranked it over. When done put all wires back on in wrong order turned over but no spark put wires in right order and still no fire. Fuel pump primes changed rotor cap, checked fuses and still no fire. Could I have burned something up putting the wires in the wrong orderand trying to start Any help? Thanks
Old 08-29-2005, 10:21 AM
200cs's Avatar
Default Re: No Spark but have fuel (98coupe)
Starting car with no plug wires on cap could have damaged coil. Hook up a plug to any wire and make sure you have no fire by grounding threaded part to block. Have a friend turn it over. If no fire, get a meter and check the coil resistance and exciter resistance and go from there. Your book should give you the values.
Old 08-29-2005, 10:54 AM
98coupe's Avatar
Default Re: No Spark but have fuel (200cs)
I was going to do this tonight had girl turn it over and no spark what so ever from plug when grounded. The meter is confusing the hell out of me on how to read it checking the coil and all using the helms. Thanks
Old 08-29-2005, 02:54 PM
98coupe's Avatar
Could starting engine with no plugs on distrubutor hurt anything if so What? Gonna try new coil tommorow.
Old 08-30-2005, 05:27 AM
200cs's Avatar
Sorry for the late reply, yes it can damage the coil or the ignition module (excitor). It may or may not always, but is not worth the risk. The coil creates enough energy to jump a .040 gap, if you are just turning it over without any path of release it may very well of damaged the unit.
There are three posts on the coil: the one the plug wire or cap hooks up to and a positive and negative. Your manual should give you resistance values to check between the posts. If it is out of limits, replace it. It should also give you checks for the module. I ususaally have my manuals in my trunk but they are at home because I was working on my turbo manifold over the weekend. Good luck.
Old 08-30-2005, 04:45 PM
98coupe's Avatar
Thanks replaced igniter and have fire. Thanks alot
Old 08-30-2005, 05:22 PM
N20civicB18's Avatar
I did that twice and both times was the stupid ignitor... actually I think I was the stupid one for doing it the second time
civicproblems
01-09-2005 03:03 PM
pnltnc
04-10-2004 03:33 PM
94civicsally
15
03-18-2004 09:50 AM
jazz215
03-13-2004 08:05 AM
Wazup
11-11-2002 01:15 AM
Quick Reply: No Spark but have fuel
