IS NGK 7 VPOWER COPPER PLUGS GOOD FOR TURBO
Old 02-07-2007, 03:32 PM
* B A N N E D *
Pnoyej6's Avatar
Default IS NGK 7 VPOWER COPPER PLUGS GOOD FOR TURBO
Im currently running ngk 9's on my ls vtec turbo 7psi 240whp and having problems with my ngk 9's boggin low rpm sometimes, not sure if its my stupid stage 3 clutch but i heard ngk 7's vpower copper plugs are good n cheaper. Wht do you guys think? I was said 9's are way too cold for my application . SHould i downgrade to ngk 7's?
Old 02-07-2007, 03:44 PM
2muchJDM's Avatar
them being too cold can definately cause a low RPM problem
Old 02-07-2007, 03:56 PM
BCICAN
Dunc's Avatar
Default Re: IS NGK 7 VPOWER COPPER PLUGS GOOD FOR TURBO (PnoyLSV-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PnoyLSV-T &raquo;</TD></TR><TR><TD CLASS="quote">I was said 9's are way too cold for my application . SHould i downgrade to ngk 7's?</TD></TR></TABLE>
I'm not sure if you meant it like that or not, but don't think that just because it's a lower number that it is "downgrading". The number is just a means of making sure you have the right plug for you application. Yes, at 240whp NGK 9's are too cold for your application. Grab some BKR7E's from Advance Auto or some place like that. Generally (don't take this as being a rule) people don't start using 9's until at least 500whp if not more.
Old 02-07-2007, 04:08 PM
TDCTyler's Avatar
Default Re: IS NGK 7 VPOWER COPPER PLUGS GOOD FOR TURBO (Dunc)
i just got some ngk 7's and gapped them to 0.25, they have been awesome so far.
i had to go to 5 parts stores to get them, it sucked. they are not BKR7E's i think they start with a Z. Has anyone heard of anything like that?
Old 02-07-2007, 04:15 PM
BCICAN
Dunc's Avatar
Default Re: IS NGK 7 VPOWER COPPER PLUGS GOOD FOR TURBO (spOolin97)
I'm assuming these are for the car in your signature? If so that's why....B series plugs are different than your H.
EDIT: I will correct myself, that's not the sole reason haha. You can get NGK BCPR7ES for the H's.
Old 02-07-2007, 05:45 PM
* B A N N E D *
Pnoyej6's Avatar
thanks guys. I will definitely pick up some n gk 7's. Is the part number bkr7e's ngk v power copper 7's. One of the shop recommend i get copper
SilverPanda
02-27-2008 08:50 AM
lacking vtec
05-20-2007 11:37 AM
integraboosted
05-02-2006 10:33 AM
Chip398193
03-18-2002 12:31 AM
quick108
11-20-2001 10:50 PM
Quick Reply: IS NGK 7 VPOWER COPPER PLUGS GOOD FOR TURBO
