My E85 Stock B16A Dyno
Old 10-04-2010, 12:20 PM
slostjoe's Avatar
Default My E85 Stock B16A Dyno
I just had my car put on the dyno yesterday and did some minor tuning and was running into boost spike problems so i was able to make these runs, I'll post the vids and dyno sheet when i get to my home computer as it will not allow me to from work.
I did several half runs and getting everything dialed in, these are the best of the 10 pulls. If i had a Electronic boost controller i could have broke 400whp easily
Mods-
Bone Stock B16A with 130k and ARP Head Studs
Ebay 57Trim Turbo
Love Fab T3 RamHorn Manifold
Tial 38mm Gate
Hondata S300 Tuned by Cruizinmax.
E85 Fuel
Fic 1050cc Blue tops Flowed at 1455cc's Stock rail and regulator.
3" DP and Exhaust
2 1/2" IC Piping but the lower IC Pipe is 1.75" Soon to be changed
Stock cams and Valve Train, Limiter set at 8,330rpms
Tial Knock-Off BOV
Hondata 4bar MAP Sensor
OEM Headgasket
Fist run on 13.8psi-342.56whp 233.80wtq at 17* of timing
Second run 14.8psi-358.68whp 244wtq at 178 of timing
Third and final run made 16.2psi-380.8whp and 287.9wtq at 19.25* of timing.
I need a bigger turbo and more steady boost. I couldn't get it to hold more than 16psi
Let me know what you think!
Vid
http://www.youtube.com/watch?v=zFjkVtyjVFE
http://www.youtube.com/watch?v=xxlM-q3ljjE
Old 10-04-2010, 12:23 PM
jv88_dc2's Avatar
Default Re: My E85 Stock B16A Dyno
wish i could boost. VERY good numbers for a stock b16!
Old 10-04-2010, 12:46 PM
averyvm's Avatar
Wow pretty impressive tuning
Old 10-04-2010, 01:02 PM
cruizinmax's Avatar
It is pretty amazing to see what E85 will do. I was helping out with the tuning and I was very surprised what range the air/fuel could be at and not affect power that much. I do believe there is 20-30 hp hiding in this car with just a little bit more time tuning, replacing that intercooler piping, and more consistent boost control.
Old 10-04-2010, 01:24 PM
slostjoe's Avatar
I agree, Its definitely amazing what E85 can do even when this motor was NA on e85 and s300 it picked up good power.
Thanks again Max without you i wouldnt have been able to do 90% of my build.
Old 10-04-2010, 01:33 PM
092eg6's Avatar
what do u think was causing the boost spike?
Old 10-04-2010, 01:57 PM
slostjoe's Avatar
Shitty manual boost controller I suppose.
Old 10-04-2010, 05:11 PM
lst_hatch's Avatar
Mods-
Ebay 57Trim Turbo
Tial 38mm Gate
E85 Fuel
3" DP and Exhaust
Tial Knock-Off BOV
OEM Headgasket
very nice numbers! i made 320whp@12psi on a stock b16 on pump gas. thinking of tuning on e85 or 110oct. and turning up the boost!
Old 10-05-2010, 06:36 AM
slostjoe's Avatar
Thanks man! Not bad numbers at all for pump gas. E85 is the ****!
slostjoe's Avatar
VIDEO IS UP!
Old 10-05-2010, 08:19 AM
turbociv910's Avatar
i made 428 on e85 with 3076 on my stock b16 setup
Old 10-05-2010, 08:47 AM
golf-mk3's Avatar
what injectors, rail and regulator?
Old 10-05-2010, 09:09 AM
slostjoe's Avatar
Fack! I need a bigger turbo! What boost and timing are you running to get there?
Old 10-05-2010, 09:16 AM
Gold DA9's Avatar
great numbers for a stock long block and e85.
Old 10-05-2010, 10:40 AM
slostjoe's Avatar
Old 10-06-2010, 01:25 PM
GEN2 LS's Avatar
damn can't wait to get my setup done it's damn near close to yours. only difference is I have ITR cams and a built head and my compression ratio is 11:1 and a 60 trim turbo, but i'm def running E85
Old 10-07-2010, 10:08 AM
lst_hatch's Avatar
so were those numbers on a completely stock b16? no cams or anything?
is the car a DD?
Old 10-07-2010, 06:19 PM
VtecCarHauler's Avatar
gsr cams alone will get that into the 400
Old 10-07-2010, 07:09 PM
1dopesi's Avatar
it's all about tuning! Wonder if I can boost that high on my set up?
Old 10-08-2010, 07:07 AM
slostjoe's Avatar
is the car a DD?
Everything is stock minus head studs. I drive it probably 1500mi a month but every second i drive it im either at the track or racing on the street or just beating the **** out of it lol.
I know that or type r cams
Its not really how much boost its like you said all in the tuning I could have ran more if i had a better boost controller, I see why now that i've done it why dyno tuning is so important.
Old 10-08-2010, 06:22 PM
sleepencivic's Avatar
what are the afr's in boost if you dont mind me asking?
Old 10-09-2010, 08:13 PM
slostjoe's Avatar
Well maximum power was achieved at 12.2-12.4afrs anything higher or lower yeilded less power the tune still needs some work and there are still some kinks to work out. Every setup is different amd every motor responds to fuel/timing differently but 12.0-12.5afr is a safe target number on e85.
Old 10-09-2010, 09:00 PM
Charlie Moua's Avatar
congrats!
great tuning
Old 10-09-2010, 09:49 PM
H.A.R.T B18C1EG6's Avatar
Very nice numbers!
Old 10-11-2010, 10:44 AM
slostjoe's Avatar
Originally Posted by Charlie Moua
congrats!
great tuning
Originally Posted by H.A.R.T B18C1EG6
Very nice numbers!
Thanks!
Quick Reply: My E85 Stock B16A Dyno
