My d16 turbo build finally finished!!
Hey all, I bought a '96 civic ex around 5 months ago for a cheaper dd compared to my lifted '13 tacoma. Well it didn't last long before I had the idea of making a little more power but also keep my ac and ps so then I started picking up parts for a d series turbo build. My part list is below.
Engine
75.5 vitara pistons
Custom lenght I-beam rods
Stock head
Arp head studs
Golden eagle cam gear
Ngk plug wires
Gates timing belt
Xtd stage 4 6 puck
Short throw shifte
8lb flywheel
Arp flywheel bolts
FIC 650cc injectors
Walbro 255 fuel pump
Omnipower 4 bar map
Ebay vacuum manifold
Turbo kit
Go-Autoworks turbo kit
Cast manifold to keep ac and ps
2.5" open downpipe
Turbonetics t3 super 60
Tial Q 50mm bov
Tial 38mm mvs wastegate
Autoworks IC piping
Autoworks FMIC
Turbosmart MBC
Innovative Motorsports wideband
Speedhut boost gauge
Speedhut oil pressure gauge
I'm sure I left some things out but that's what I can think of off top of my head.
Car was tuned by Howard at RLZ engineering on neptune at 17lbs and made 293whp and 240ft lbs on a dynapack dyno. Greg at Go-autoworks was great to deal with and was there to answer any questions I had and always offered great advice. I high recommend his kit as well as RLZ engineering for work or tuning if anyone is within a few hours of charolette, NC area.
Engine
75.5 vitara pistons
Stock head
Arp head studs
Ngk plug wires
Gates timing belt
Xtd stage 4 6 puck
Short throw shifte
8lb flywheel
Arp flywheel bolts
FIC 650cc injectors
Omnipower 4 bar map
Turbo kit
2.5" open downpipe
Tial Q 50mm bov
Autoworks IC piping
Autoworks FMIC
Turbosmart MBC
Re: My d16 turbo build finally finished!!
93
Yeah a slight improvement over stock haha
Thanks I appreciate it!!
Seems to be quite laggy for such a small turbo... Makes power slower than my STC GT35. Seems like something isn't right.
Nice build though!! Congrats!
Yeah it get annoying after a while. I'm gonna order a 2.5" downpipe that comes out of the front bumper from Go-autoworks in the near future.
What compression is your motor? And thanks man
Keyboard Humorist
I was thinking the same as it looks similar to an old school nitrous curve.
It looks like it would feel like a stock engine if you stay under 4500.
Seems a bit early to be shifting, but it looks possible to do so and just stay out of boost for normal daily driving.
With passengers - hold the accelerator at 4500, look over at your passenger and tell them to hold on for their life, and then gun it!
Man U FTW
The scaling on that graph is goofy...i dont like it.
Also, I would have thought a tiny little super 60 would have spooled much sooner than this.
OP: What is the compression ratio? I might have missed it...
Op looks like a solid build though. Good job.
