What else would you recommend for turbo build???
Below is a list of parts for my winter turbo build for my 2000 Si. I plan to purchase the turbo kit from AFI and pick up the parts over the winter and have the car ready to go next spring. My goal is 300whp with stock internals. I've already replaced the clutch with an ACT Heavy Duty and ACT Prolite flywheel. I also have a DC Sports dual bend short shifter.
What else would you guys suggest or recommend? Am I missing anything?
Any suggestiontions or recommendations are very much appreciated. Thanks!
-AFI turbo kit (ac compatible) with GT28RS turbo
AFI Ramhorn Manifold, 3" dp, stainless dumptube, 2.5" aluminum IC piping
Garrett 24x6x3.5 FMIC (450hp)
Tial 44mm wastegate
Tial 50mm Bov
All couplers/clamps
Oil feed and return
All nuts/bolts/hardware..
-Hondata S300
-RC Saturated 750cc Injectors
-Walbro 255lhp fuel pump
-Aeromotive fuel pressure regulator
-ARP head studs
-Slim fan
-Heat wrap
-Gauges: oil pressure, vacuum/boost, fuel pressure, exhaust gas temp (egt), wideband air/fuel gauge
-3 bar map sensor
-NGK 7 spark plugs
-NGK plug wires
-Replace OEM cap/rotor/ignitor with new OEM pieces
-Hondata gasket
-Mishimoto aluminum radiator
-LSD?
Tial 44mm wastegate
Tial 50mm Bov
All couplers/clamps
Oil feed and return
-Hondata S300
-ARP head studs
-Slim fan
-Heat wrap
-3 bar map sensor
-NGK 7 spark plugs
-NGK plug wires
-Hondata gasket
-LSD?
Re: What else would you recommend for turbo build??? (ken00si)
I'm looking into LSD's right now, what LSD would you guys recommend for this setup...CTR, ITR, Cusco, Quaife, Kaaz...???
