max hp with e85 and single walbro
Old 04-06-2009, 06:36 PM
thegatekeeper14's Avatar
Default max hp with e85 and single walbro
alright i have a walbro 255 and im gonna run e85 whats the pax power i can make? and if i do line whats the max i can make then
i also have a fpr/ gauge and str fuel rail. thanks a bunch
Old 04-06-2009, 06:53 PM
SilverEk3dr's Avatar
Default Re: max hp with e85 and single walbro
Im gonna have to be the first to say search. Or at LEAST have a Hp goal in mind. From experience with my own build ur gonna be limited to around 450whp.
Old 04-06-2009, 06:57 PM
HELLO,GOOD MORNIN'
ahobbs's Avatar
base pressure will be important.
with stock base pressure depending on your injectors, id say 450ish.
bump the pressure and you can get 600
Old 04-06-2009, 07:26 PM
U talking about running the ID1000's? Is that how u benefit from More Psi? Or just on ur average 1000cc+ injector?
My bet is that a walbro would run out of volume at higher press. Higher press = less flow right? So not sure how more press will really help with just a single walbro??
Old 04-06-2009, 07:43 PM
HELLO,GOOD MORNIN'
ahobbs's Avatar
well I should have stated adding an inline pump, sorry.
Old 04-06-2009, 07:51 PM
Oh, just curious. Thought I was missing something
Old 04-07-2009, 09:22 AM
otherwise im looking at having to buy a aeromotive 1000 +lines set up, and id like to see where i end up with just the single walbro. would you say 500hp is do-able?
Old 04-07-2009, 10:19 AM
red02s2k's Avatar
I had a single walbro with rc1000 and I made 450 at 18psi. Tony told me thats about it in less we change the fuel or the go two a dual setup!
Old 04-07-2009, 10:51 AM
E85B18's Avatar
Wouldnt it be important to know the turbo and cam set up? Ive seen 500 on a single walbro
Old 04-07-2009, 11:47 AM
gringotegra's Avatar
Ive seen 500whp also with a single walbro... it wasent on a honda it was on an Evo with 1200's...
Old 04-07-2009, 01:15 PM
96 GSR-T's Avatar
I have seen high 500's on a single 255 and E85 but the car was a freak of nature.
I can tell you from personal experience an intank 255 to an inline 255 will hold fuel pressure for upper 500whp on E85, dont know what happens beyond that.
boosted2.4
02-05-2010 06:54 PM
HarfordCTR
05-27-2009 11:50 AM
xtrec02
06-06-2007 08:40 AM
mmmVTEC
07-30-2004 12:28 AM
Familycarfromhell
02-11-2003 06:01 AM
Quick Reply: max hp with e85 and single walbro
