K24a3 head or k24a2 head or k20a2 head fro turbo application ?
Old 10-19-2015, 10:11 AM
u_tal's Avatar
Default K24a3 head or k24a2 head or k20a2 head fro turbo application ?
Hi guys! I'm planning big turbo swap for my ek, just wondering if I can stay with my k24a3 head or other head??? Or just replace the cams???
What do you think?
Thanks for all
Old 10-19-2015, 10:24 AM
Moderator
TheShodan's Avatar
Default Re: K24a3 head or k24a2 head or k20a2 head fro turbo application ?
Keep the cams, keep the head. All depends upon power level, purpose, which turbocharger you're using (PLEASE DO NOT GIVE US "PSI/BAR" LEVELS, THAT MEANS NOTHING), just like in the last thread you made..
Originally Posted by u_tal
I'm going to 800hp , so it's really issue this moot... Soon I will have to decide.
If you're still stuck on THIS aspect, then the head won't matter. It's what you do with it. Camshaft you'll need to see the people in Drag Racing, like Kelford, Drag Cartel, and Pryoonto Racing for all those answers. Contact them directly with your full build specifications. You'll get MUCH better answers than here, because... It's all based upon preference, cost, and purpose.
Get the basics first. Turbocharger and exhaust manifold choice will need to be determined first . Then you can play around with the "head games" *snicker* excuse the pun.
Old 10-19-2015, 10:41 AM
u_tal's Avatar
You are really something! Good memory! That is for the help, some guy told me that I need to replace the intake manifold, I tried to search it, but no result ...
The turbo I'm using is GT4292
Thanks again!
Old 10-19-2015, 11:13 AM
Moderator
TheShodan's Avatar
You must mean the GT4202 Turbocharger, or GT4294, which is really more for over 1000hp. 800whp can be done by many others.
Considering that either one uses a 4.2" inlet as a v-band clamp, you've got your work cut out for you.
The intake manifold choice will be based upon the exhaust manifold and intercooler piping setup that you use. You can use anything from an eXcessive Motorsport central plenum styled manifold, to an RBC or similar exhaust manifold.
Like I stated, Choice is on Turbo/ exhaust manifold , then you worry about the other stuff. Start checking out the the other 800hp GT42 setups on the Drag racing forum to make some decisions.
Look at what FITS first (including what fits your budget), THEN worry about the intake manifold.
Old 10-19-2015, 11:46 AM
u_tal's Avatar
My BIG question is about the camshaft , are they the same in my k24a3 head or they are different , also almost the same will good answer to me... ��
Old 10-19-2015, 01:26 PM
Moderator
TheShodan's Avatar
You'll need something aftermarket for that power goal anyway, so, it really doesn't matter if they're the same or not (They're basically the same OEM, anyway.)
ep3man
07-02-2010 01:01 PM
bigsnorlax
04-28-2009 11:00 AM
butch11a
Welding / Fabrication
01-03-2005 07:46 AM
VtecRacaChick
01-29-2004 10:30 PM
Quick Reply: K24a3 head or k24a2 head or k20a2 head fro turbo application ?
