i bought Supertech pistons...anyone else use them?
Old 10-21-2004, 10:39 PM
ojoemamao4o's Avatar
Default i bought Supertech pistons...anyone else use them?
Supertech pistons are manufactured from extruded high silicon, enhanced 4032 alloy that low thermal expansion, excellent wear resistance and higher thermal conductivity. A phosphate dry lubricant coating is applied to pistons to protect against ring micro welding and ehance skirt lubrication
Supertech Performance has more than 30 years of experience under its belt in the design of racing pistons and the utilization of the latest CAD software & Finite Element Analysis enables them to design strong high-performance lightweight pistons for each application. Supertech pistons are manufactured from extruded high-silicon, enhanced 4032 alloy (with additional Cu, Ni & Mg) that has low thermal expansion, excellent wear resistance and higher thermal conductivity. A three step forging process yields a fine structural grain oriented in fibers in the same direction of the stresses. Several heat treatments provide the piston with a high tensile strength and evenly distributed hardness that will withstand boost up to 42psi. The slugs are CNC machined with special diamond tools for dimensional precision, perpendicularity and flatness of the ring grooves. Contact reduction grooves are standard. A “phosphate dry lubricant” coating is applied to protect the rings against “micro welding” and enhance lubrication on the skirt/cylinder area.
copy pasted...they were on an introductory sale at the shop i go to for 350!!! i couldnt pass it up...i went supertech because they have a good backround with engine performance, hope these pistons a can hold up...wondering if any out turbo b18s are running this setup for turbo, i bought 81.5mm 9:1 compression
Old 10-21-2004, 10:53 PM
Better than steak
Arturbo's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (ojoemamao4o)
Last time I saw some they were very heavy. But that doesnt mean that the final product are heavy.
Old 10-21-2004, 11:00 PM
Rob Dizzle's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (Arturbo)
I remember hearing about the project like 18ish months ago
cool to have something out. its interesting, because there are alot of other piston comapnies out there already. but if they are going to be marketing with a cost leadership styles (lowest price pretty much) then it could be a hot seller
Old 10-21-2004, 11:14 PM
Default Re: i bought Supertech pistons...anyone else use them? (Bob-DC2)
yeah, im liking the thermal coating
i was getting cp pistons, 440 but when i called the shop to order then they told me about this deal 350 for the supertech psitons....awesome
all i need now are oem gaskets and seals for the bottom and top end then i can putt her all back together
Old 10-22-2004, 12:25 AM
Joseph Davis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">Last time I saw some they were very heavy. But that doesnt mean that the final product are heavy. </TD></TR></TABLE>
Even if they are, us low revving LS guys don't care much about rpms like you slow VTEC guys do. A little extra weight doesn't mean so much
Old 10-22-2004, 01:55 AM
GLHS895's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (J. Davis)
last i heard hypereutetic (silicon-alloy) pistons suck for boost. crack, fall apart. you name it, they do it.
of couse, this is just what i've been told. i've only seen it in one instance, and it was in a kragens brand 'recon' motor. we all know those are budget motors, naturally they use budget materials (hypers are cheaper to make).
i'm willing to bet they've developed a bit and can take some boost(heat) now. the ad specifically says 42psi
Old 10-22-2004, 04:22 AM
Oyvind Ryeng's Avatar
Is it just me or does those ringlands look dangerously thin?
Old 10-22-2004, 05:35 AM
.nate's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (GLHS895)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GLHS895 &raquo;</TD></TR><TR><TD CLASS="quote">last i heard hypereutetic (silicon-alloy) pistons suck for boost. crack, fall apart. you name it, they do it. </TD></TR></TABLE>
Are you sure these pistons are hypereutectic?
Old 10-22-2004, 06:29 AM
Freemantle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ojoemamao4o &raquo;</TD></TR><TR><TD CLASS="quote">yeah, im liking the thermal coating
Those aren't thermal coated in the jet-hot sense. That would be stupid. If the heat isn't in your piston, theat leaves more to be in the sleeves and combustion mixture.
If I blow up this block, I might look into those. Building a block is stupid expensive.
Old 10-22-2004, 06:36 AM
Finland's Avatar
Let us know how they work out.
Old 10-22-2004, 06:48 AM
Enthalpy's Avatar
I love posts like this...
"Hey guys i just dumped my life savings on part X from brand Y. is part X from brand Y any good? Or am i screwed like altar boy making an afterhours visit to his priest?"
HAHAHA...hope they work out for you man...it's only your engine afterall. what can go wrong?
Old 10-22-2004, 09:05 AM
done's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (Enthalpy)
sorta stupid questino? are those foruged?
Old 10-22-2004, 09:10 AM
miller's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (Jordo)
supetech pistons huh? can you give us anymore info about them?
they look like Mahle pistons.....
Old 10-22-2004, 09:13 AM
B00ST2nR's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (miller)
not sure about their pistons, but I've heard nothing but GOOD things about their Valvetrain components.
Old 10-22-2004, 10:38 AM
GLHS895's Avatar
Default Re: i bought Supertech pistons...anyone else use them? (.nate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .nate &raquo;</TD></TR><TR><TD CLASS="quote">
Are you sure these pistons are hypereutectic? </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ojoemamao4o &raquo;</TD></TR><TR><TD CLASS="quote"> Supertech pistons are manufactured from extruded high silicon, enhanced 4032 alloy</TD></TR></TABLE>
Old 10-22-2004, 10:42 AM
Substitute the word "detonation" for "boost" and you win a cookie!
Then again, most any piston sucks for detonation...
Old 10-22-2004, 11:13 AM
FredoSP's Avatar
its good to see another product come to the market
Old 10-22-2004, 11:25 AM
Default Re: i bought Supertech pistons...anyone else use them? (FredoSP)
well they should be in this weekend or at the latest, beginnning of next week, all i need now is engine seals and gaskets then i can start putting her all back together, i have a personal goal of starting the engine by halloween...ill try to shoot some pics thanks guys for the comments
Old 10-22-2004, 11:38 AM
LoSt is BlaCk's Avatar
Location: Just Drank A 5th of VODKA Dare me to drive, Ca, u.s.
the coating still scares me...i have seen them work before but i could not bring my self to using those...
Old 10-22-2004, 12:22 PM
GLHS895's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J. Davis &raquo;</TD></TR><TR><TD CLASS="quote">
Then again, most any piston sucks for detonation...</TD></TR></TABLE>
it damn well better be an oreo!
common mistake. but i'm sure the general consensus is: hypers = crack easy with detonation. sure, if you tune it to perfection and you always drive during good conditions then i'm sure they'll work fine. but how many people have it that good?
Old 03-09-2009, 08:21 AM
DRtools's Avatar
I wonder how well the 11.9:1 pistons would work with a built N/A ls-vtec.
Old 03-09-2009, 08:37 AM
92redhatch's Avatar
bringing back the dead!
Old 07-17-2009, 12:21 PM
Rease3's Avatar
^^^fail super dead thread.
Old 07-17-2009, 04:36 PM
purpleh22's Avatar
Supertechs have been around for quite a while. haven't heard that they are any more (or less) problematic than other popular brands. No those aren't hypereutectic.
jerrys7583
06-15-2012 08:00 PM
IIXtremeHansen
33
04-15-2008 08:42 AM
Wheelman-CZ
01-07-2008 12:52 AM
TurboT
11-28-2001 01:42 PM
Quick Reply: i bought Supertech pistons...anyone else use them?
