HOW TO INSTALL AN FITTINGS!!!!
Old 12-12-2009, 07:35 AM
  #26
Dnizzle's Avatar
Default Re: (DfwBB6)
Originally Posted by 905_Legend
Try cutting the steel braided line with a concrete chisel, makes a much cleaner cut.
A metal cutting band saw works great or a port-a-band. Never even thought about a chisel. hmmmm...
Old 12-17-2009, 05:48 PM
  #27
92hondalude's Avatar
Default Re: HOW TO INSTALL AN FITTINGS!!!!
summit sells this. best 15$ youll ever spend
Old 12-17-2009, 05:58 PM
  #28
Moderator
TheShodan's Avatar
STICKY TIME.
Old 12-18-2009, 04:11 PM
  #29
A.E Motoring's Avatar
good job buddy
Old 02-26-2010, 02:06 PM
  #30
HondaWhisperer's Avatar
Thank for the write up! Very much needed.
Old 02-26-2010, 11:06 PM
  #31
i HAS questions ?
.dave's Avatar
Just put masking tape on the fittings if you don't want to scratch the anodizing.
Old 10-07-2010, 05:24 AM
  #32
Charlie Moua's Avatar
I'm curious... what makes the SS line "stay" in the An fitting head?
Is it the twisting action where the SS braids bind to the inside of the head fitting?
Old 10-07-2010, 07:22 AM
  #33
Moderator in Chief
Muckman's Avatar
Its compressed between the fitting and the hose end. Same action that makes it seal.
Old 10-07-2010, 11:49 AM
  #34
sflemon's Avatar
I 100% agree........buy a 4" wide chisel with the yellow hand protector, use a standard 5 lb. hammer, and cut it.
IMHO do NOT use tape. The tape obviously frays the metal braid when you remove it. If you do it this way, you don't even need the little cool tool for inserting the lines.
You need: chisel, 5lb hammer, a concrete floor or a block of wood
I like the kind with the rubber inside vs the plastic tube. And the Summit offbrand fittings work 100% the same as the expensive brands.
Old 10-08-2010, 04:31 AM
  #35
per4mance's Avatar
Instead of using tap, usa a zip tie. Cut the zip tie with a metal cutting chop saw right up against the zip tie. What that will do is, the zip tie will keep the ends from fraying and all you have to do is pul the zip tie off the end and you have a nice smooth hose end .
Old 10-08-2010, 03:28 PM
  #36
Root of all Evil's Avatar
I use heater hose for everything. 10 years+
Old 01-25-2011, 06:29 PM
  #37
kirkland08's Avatar
can you use non braided hose on An fittings? or is it just best to use the steel braided ones?
Old 02-27-2012, 07:19 PM
  #38
SiRCiviC94's Avatar
very helpful
Old 10-06-2012, 07:51 PM
  #39
Boricuanology's Avatar
Anybody know what size of box end wrench to use with 8, 10 and 12 AN fittings? Also while doing this, I guess you don't need to wrap the fittings with tape to protect the finish, I thought that being that the wrench is steel and not aluminum it would have damage the finish.
Old 02-15-2013, 12:17 PM
  #40
B R Fittings's Avatar
www.brfittings.com
For future reference for everyone else. These are for B & R Fitting hose ends, other brand fittings may differ.
AN 4 straight 14mm
AN 4 45º,90º,150º etc. 5/8"
AN 6 19mm
AN 8 1"
AN 10 27mm
AN 12 1 1/4"
You have to use a box end ratcheting wrenching. I use the brand Gear Wrench. Any quality ratcheting wrench will work.
The reason they don't scratch the fittings is the ratcheting wrench has 12 contact points to grab around the fitting.
huge230
11-27-2007 11:49 AM
Race Egr
Welding / Fabrication
09-23-2005 11:26 AM
T-RO
02-24-2004 08:44 PM
Xerxes
01-27-2002 10:48 PM
Quick Reply: HOW TO INSTALL AN FITTINGS!!!!
