Deciding on the right Precision turbo
Old 12-08-2011, 02:00 PM
EscoSi's Avatar
Default Deciding on the right Precision turbo
Hey guys, I'm planning on turbo-charging my em1 in the new year but am having trouble deciding which turbo I want to run. I know for certain that I want a Precision turbo.
Here are the specs that I will be going with:
B18C1 Block:
Eagle H-Beam Rods (with ARP Rod Bolts)
CP Pistons 9.0:1 (that is the suggested compression to use here... no higher)
LS crank
ACL Race Bearings
Golden Eagle Block Guard
ARP Studs
'00 ITR Head:
Ported & Polished
Brian Crower Titanium Valve Springs
Brian Crower Retainers
Supertech Flat Valves
'99 CTR cams
'00 ITR Manifold (ported to 70mm)
Skunk2 70mm TB
Spoolin Performance Mini Ramhorn Manifold (AC & PS compatible - want to keep both, it gets pretty hot here even now during the days lol and I love my PS)
Spoolin Performance 3" DP
38mm Tial Wastegate
Precision 600hp Intercooler
HKS Blow-off
Walbro 255
Precision 1000cc injectors (This should be more than sufficient)
75 shot wet NOS kit (In case I decide to hit up a drag strip)
It will be dyno tuned on Neptune.
Wondering if I can run 3" exhaust piping with a resonator to an Apexi WS2 turbo exhaust and have a Summit Racing Electronic Cut-out.
Transmission:
B16 Tranny with LSD (LS final gear & 4.7 Final Drive)
Gearspeed Carbon Synchros
Clutchmasters FX400 6 puck Clutch kit (I've had great experience with this brand)
Clutchmasters Flywheel
Brakes & Suspension:
Brembo Blanks (front & rear)
Hawk Pads
Steel Braided Lines
Tein Street Basis coils
Spoon strut bars (front & rear)
Stock Si sway bars (front & rear)
Stock Si tie bar
Can't remember what else I have.
Oh, I might get a deal on a meth kit as well.
What do I want to do with the car? - I want it mainly for street and with a fast spool. I'm not too into top end power. I like being able to get up and go and like corners etc. so it's not necessarily for a straight line. I'm not into street racing just want it for my own personal fun. Want to make between 400 and 500hp (low to high boost). I know the set-up might seem like overkill to some ppl but I'd rather do the set-up properly than half *** it even if its not a 11 second car.
By the time I'm ready for this build in the new year the car will be a weekend driver.
I've been looking at the Precision 4431, 5252 & 6031. But I don't know which of these would be ideal for what I want. Also what's the difference between the 4431 and 3431?
Am I going in the wrong direction with these parts?
Old 12-08-2011, 02:33 PM
Turbo-LS's Avatar
Default Re: Deciding on the right Precision turbo
Why stuck on a precision turbo? there great and all but there are many other options out there for your power goals.
Old 12-08-2011, 02:45 PM
shanebadoo's Avatar
Was just about to say the same thing. The Shodan has great alternatives with better mid range spool. Check locojoe's thread you might think different. The next turbo I buy will definitely be a shodan turbo.
Old 12-08-2011, 02:48 PM
Turbo-LS's Avatar
Im going to pick up a STC reaper my self next year for my GSR
Retired Moderator
EsotericImage's Avatar
street car with 400-500 hp that weighs roughly 2500lbs..
can u say no traction
Old 12-08-2011, 03:23 PM
Turbo-LS's Avatar
im making over 400whp and i get perfect traction in all gears but 1st.Boost by gear is your friend !
Old 12-08-2011, 03:38 PM
Retired Moderator
hmm, alright! rock on!
Old 12-08-2011, 04:52 PM
All Motor Mentor
00Red_SiR's Avatar
If you want something with a quick spool, why would you want to run nitrous? That's normally used to help a big turbo spool up quicker.
Old 12-08-2011, 05:01 PM
GEN2 LS's Avatar
I'm running a Precision 6031 .63 hotside on my car, full boost by 4,700-4,800rpms on a b16, it works for my budget. If I could do it all over again I would have gone with a 3076R from Garrett though.
Old 12-08-2011, 05:05 PM
LocoJoe's Avatar
For that goal u dont need nitrous. 1.8L motor will achieve that goal no sweat. TheShodan has the TR3030 (I believe thats the identifier) quick spool and good top end. I suggest the OP to do some more research in here.
Old 12-08-2011, 05:10 PM
CrackingVTEC's Avatar
^ That....
Old 12-09-2011, 04:49 AM
EscoSi's Avatar
Here in Jamaica, most of the ppl I've spoken to recommended Precision for the turbo of choice. I've actually never heard of a shodan turbo to be honest lol but I'm going to take your advice and check out the threads.
I'll also pass the 75 shot to my bro to use on his type r.
Old 12-09-2011, 06:26 AM
EscoSi's Avatar
I read your post on the reaper and damn. that's all i've got to say. I did some reading on the TR3030 but am still curious as to what rpm it will actually start building boost. Am I going to have turbo lag until 6k and redline at 9 or should it spool much quicker than that?
I'm curious also on your thoughts of my exhaust with the electronic cut-off... I honestly don't like having a super loud exhaust on my car, those days for me were for when I was much younger. So driving it "around town" I don't really want to attract unwanted attention from the po-pos but if I go to the track then I can switch tunes and use the cut-off.
That's my thinking.
Old 12-09-2011, 08:58 AM
LocoJoe's Avatar
As you've read my thread I have the Reaper on a B16 and it spools super nice. Like its been said, you cant have big top end and quick spool. My setup starts making boost at around 5000rpms and full boost at 6000-6200. My revlmiter is at 9800 since B16s like it up there. The TR3030 has smaller wheels which I believe will spool faster than the Reaper. Maybe TheShodan can chime in on this since its his creation.
The reason I went with him is aside from custom wheels designed to be more practical in street driven cars, great service and products. The most important factor is that if you need to rebuild it, any authorized technician can repair it since its based off genuine Garrett parts. Precision turbos you need to send to the company and the turnaorund time can get crazy. Also Precision turbos, some of them have faults straight from the box. Shodan's products have a 0% failure rate due to assembly or materials.
Electronic cutouts are the best thing invented for street driven cars. I feel the same about the noise when driving around town. Get the cutout, you wont regret it.
phaphon
08-09-2010 02:05 PM
solattack77
10-23-2009 03:39 AM
done
02-04-2006 08:27 AM
Quick Reply: Deciding on the right Precision turbo
