gsr turbo vaccum diagram (all vaccum line)
Old 08-08-2011, 06:31 PM
ja20_eg's Avatar
Default gsr turbo vaccum diagram (all vaccum line)
is there a diagram on H-T for how to hook up all vaccum line for a turbo set..like wastgate,bov,boost gauge,ect..pis would help alot and easy..thanks
Old 08-08-2011, 08:21 PM
dopehouse's Avatar
Default Re: gsr turbo vaccum diagram (all vaccum line)
i just ran mine like normal except put a t between a line for the bov and a t for the boost gauge. then i used a t for my map sensor with check valves in the middle. and i ran the wastegate vaccum right off my turbo. sounds ghetto but runs perfect.
Old 08-09-2011, 02:23 PM
ja20_eg's Avatar
any diagram..that would help
Old 08-11-2011, 10:29 AM
dopehouse's Avatar
just made this haha. not the best but you get the idea
Old 08-11-2011, 03:56 PM
ja20_eg's Avatar
nice..so where the plug in the middle of the wastegate go to...i got one on the side of the wastgate n one in the middle???could i plug up the one in the middle....
Old 08-11-2011, 04:11 PM
racebum's Avatar
that seems complicated and using the fpr vacuum isn't the best source.
the pcv would be where i would tap since it's disabled for the catch can
Old 08-12-2011, 02:07 PM
dopehouse's Avatar
alright ill try it off the pcv. can i just get a gm map and eliminate the vaccum valves?
and i just have the vaccum line on the side hole for the wastegate. you only need to use both if you are using a boost controller.
almostjdmeg
03-10-2008 01:00 PM
The Dirty EJ1
06-10-2007 02:31 PM
almostboostedgsr
03-14-2007 08:23 PM
leinadmiih00
01-20-2007 04:58 PM
VanHonda
06-08-2003 04:01 AM
Quick Reply: gsr turbo vaccum diagram (all vaccum line)
