blown head gasket?
blown head gasket?
Hello I just bought a car from someone that said the motor was fully built the car is not tune. Me being dumb I drove it to make sure it doesnt die out or overheat. It was fine so I bought it the next day I was changing my oil I notice the oil was milky... so I changed the oil and did a compression test number was 40, 60, 70, 80 acceoss the board. But the motor idle fine and sound fine....
Re: blown head gasket?
89 crx Darton sleeve 84mm bore eagle rod wiseco piston 8.5.1 compress itr oil pump arp main and head bolt gsr grutle itr head with super tech valves train Victor x manifold 880 cc persicion. 255 walbro am cam gear 7 lb fly wheel turbonectic wastegate garret turbo log manifold
you also might want to double check if the autozone hg will work. correct me if im wrong, but a b20 hg wont work on a 84mm gsr block
my motor is idling fine and not over heating when park but what I dont understand is would I hear are notice anything wrong if compression test number was 40, 60, 70, 80?
I called the guy I bought the motor from and he said it never over heated on him, he said the car sat for 2 month only before he sold it too me but that doest explain the very very low compression test it doest make sense
The Grumpiest
Healthy MINIMUM compression numbers are 135psi. Your numbers are beyond past bad at this point or you messed up the compression test badly. A blown headgasket doesn't necessarily have to cause the engine to overheat either. Keep driving it like that and you'll be sorry. Change the damn headgasket.
just remove my head at least the guy was right about the block is being built...
will finish puting the new gasket on next sat hopefully it will bring the compression back up. What is a good compression for 8.5:1?
Just A thought, I wonder if you can get the block resurfaced to the sleeves (if in service limits)? If anything you need to find out how much lower the sleeves are, Im sure this is bad...
Who is Mr Robot?
Your spelling and grammar makes me want to beat retarded children...
Those are dart on sleeves, everything looks fine, clean all of that **** out of the cylinders and put the new gasket on already..... the questions you're asking we can't answer unless we can physically touch the damn motor
Install the damn gasket already and go from there
