eBay turbo kit on d16y8?
Old 08-02-2016, 02:24 PM
Mrnieves98's Avatar
Default eBay turbo kit on d16y8?
Is a 500$ eBay turbo kit good enough to get my d16y8 on 7psi? Has anyone had any experience with eBay turbo kits?
Old 08-02-2016, 02:55 PM
2kdrift's Avatar
Default Re: eBay turbo kit on d16y8?
they tend to fail after a few hundred miles, depending on how hard you push them, also puts the health of your motor in jeopardy when they do fail. Just dont do it
go here instead:
GO-AUTOWORKS Turbo Kits Honda Civic Acura Integra D16 B16 B18
Old 08-02-2016, 03:01 PM
Mrnieves98's Avatar
Ok so besides that kit, what will I need?Besides injectors, wideband, fuel pump, p28 ecu?
Old 08-02-2016, 04:11 PM
2kdrift's Avatar
well you need more the just a "p28" ecu, most people here run Hondata or similar which can be installed into a P28 ECU, I bought my ECU complete with hondata pre installed which will then need to be tuned by a professional. pretty sure all this stuff is in the FAQ somewhere
other then that perhaps a catch can, upgraded clutch and motor mounts depending on your power goals
Old 08-02-2016, 04:23 PM
Mrnieves98's Avatar
Yea I forgot to list the s300, but my power goal is 200whp even or a little under is acceptable so I don't think I'll have to get upgraded mounts
Old 08-02-2016, 04:36 PM
2kdrift's Avatar
yea at that level Stock mounts should be OK, stock clutch should be OK also as long its current health is good
Old 08-02-2016, 04:42 PM
Mrnieves98's Avatar
Yea actually just bought the car a month ago and the clutch is pretty much brand new.. Not sure if it's an OEM clutch or and aftermarket.. The guy I bought it from only had it for a couple months and didn't know anything about what's been done to it
Old 08-02-2016, 06:53 PM
Premium Member
Aradin's Avatar
It should be an Exedy or something along those lines. Autozone or equivalent aftermarket clutch will burn out quick. Seen it happen on a similar setup to what you're wanting to do. Mounts should be okay for awhile but you'll kill them quicker. Rear mount will be the first to go. Engine will start flopping about like a fish out of water when it does.
Old 08-03-2016, 04:48 AM
Man U FTW
Schister66's Avatar
You don't need Hondata - if you're looking for a budget friendly option, Crome is free and Crome Gold is like $100. People tend to overlook them as options, but they exist and offer all the features you'll need for this setup.
Old 08-25-2016, 05:32 PM
ThatBoostedEj8's Avatar
I went the ebay route on my y8 and i will never do it again. first problem was i and to cut and re weld the downpipe because it was not even close to fitting, most of these kits don't even come with everything you will need. all of the bolts on all of the parts are terrible quality, everything is just really cheap quality, but you get what you pay for.
Old 08-25-2016, 06:05 PM
pogeeboy27's Avatar
We need more posts like this to steer people away from that crap.
MTracing
11-07-2011 06:24 PM
lil4cl
Engine Management and Tuning
06-30-2010 02:42 PM
96integralsvtec
09-10-2009 12:28 PM
Boosted Bondo Spot
05-02-2005 06:32 PM
Quick Reply: eBay turbo kit on d16y8?
