Compare t3/67 vs gt35/40r vs gt3040
Old 03-07-2005, 07:45 AM
done's Avatar
Default Compare t3/67 vs gt35/40r vs gt3040
This is what i have so far.
Specs Taken from Full-Races webpage
T3/67
Compressor Specifications:
-T04R 67mm compressor wheel with a max flow rate of 75 lb/min
-0.70AR T04S compressor housing
-Good to 650whp
Turbine Specifications:
-stage 5 turbine wheel
-0.63 or 0.82 A/R. turbine housing available
-4 bolt standard turbine discharge
CHRA Specifications:
-360 degree thrust bearing standard, optional 360 deg.
-Oil cooled&lubricated center section.
Questions on the t3/67:
What is the actual trim of the turbo? What is the actual size of a stage 5 t350 wheel?
Specs taken from atpturbo.com
GT3040
Compressor:
-Wheel: 82mm w/ 56 trim
-Housing: .70 ar
Turbine
-Wheel: 60mm w/ 84 trim
-Housing: .63 ar, .82 ar, 1.06 ar
GT35/40r
Compressor
-Housing: .70 ar
Turbine
-Wheel: 68mm w/ 84 trim
-Maps
Questions: Can anyone translate these compressor maps?
gt3040
turbine
compressor
gt35r
turbine
compressor
My questions on the whole topic. Each turbo claims to put up to 600hp. Which is gonna have the quickest spool, and which will have the best powerband??
Motor setup:
84.5mm 9.5:1 pistons
ITR stroke
Equal length manifold
edit: Ive read through all the "t3/67 vs gt35r", the opinions are so back and forth, it seems like nobody knows whats going on between the two.
If a gt3040 is almost identical with my setup, then how can a gt35r, which has a larger turbine housing be so comparable also?
Modified by Jordo at 11:23 AM 3/7/2005
Old 03-07-2005, 07:48 AM
done's Avatar
Default Re: Compare t3/67 vs gt35/40r vs gt3040 (Jordo)
now to compare my dyno to mikes01gsr (hope you dont mind)
t3/67 vs gt3040
info taken from.
http://www.evans-tuning.com/viewtopic.php?t=462
myself and mike basically have the same setups
my 9.5:1 vs his 9.0:1
dyno dynmaics vs dynojet
but the numbers are very comparable
Old 03-07-2005, 08:09 AM
DLB1994's Avatar
he has a way sicker power band all most looks like mine
yours very peaky his car should be a little faster
Old 03-07-2005, 08:16 AM
done's Avatar
Default Re: Compare t3/67 vs gt35/40r vs gt3040 (DLB1994)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DLB1994 &raquo;</TD></TR><TR><TD CLASS="quote">he has a way sicker power band all most looks like mine
yours very peaky his car should be a little faster </TD></TR></TABLE>
They dyno graphs are scaled differently. The graphs are almost identical.
Old 03-07-2005, 08:29 AM
Mikes01GSR's Avatar
Jordo,
From what I've been researching people are saying that the GT35R is a better matched turbo. When I purchashed mine, the GT35R didn't exisit. Geoff from
full-race and others say the GT35R will spool just as fast as the 3040R if not
faster being the turbine and compressor are more evenly matched. I also believe
the GT35R will make more power. I don't think the 3040R would put down 600whp I'm guessing 550-560whp tops.
Old 03-07-2005, 08:30 AM
DLB1994's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jordo &raquo;</TD></TR><TR><TD CLASS="quote">
They dyno graphs are scaled differently. The graphs are almost identical.</TD></TR></TABLE>
ohh arigth i see now odd scaled , was yah at the same boost? what was your peak wtq?
Old 03-07-2005, 08:31 AM
done's Avatar
yeah same boost level about 15psi, i dont know my exact tq.. whatever the graph says
Old 03-07-2005, 09:04 AM
Smarter than you
DIRep972's Avatar
Default Re: Compare t3/67 vs gt35/40r vs gt3040 (Mikes01GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikes01GSR &raquo;</TD></TR><TR><TD CLASS="quote">Jordo, When I purchashed mine, the GT35R didn't exisit. </TD></TR></TABLE>
Damn, how long ago did you purchase your 3040? 2002?
Old 03-07-2005, 01:03 PM
Mikes01GSR's Avatar
Default Re: Compare t3/67 vs gt35/40r vs gt3040 (DIRep972)
Sometime in 03 I believe. At the time Geoff at full race had only sold a handful of GT turbo's. Jordo I you planning on getting one of the 3?
Old 03-07-2005, 01:10 PM
Smarter than you
DIRep972's Avatar
Oh ok, well then the gt35r did exist when you bought your turbo. Vaportrail started dealing them on H-T in 02'.
Old 03-07-2005, 01:19 PM
Mikes01GSR's Avatar
Well I'm going by what Geoff Told me, unless the GT35R Turbine was not available to him for some reason. The Compressor on my GT3040R is exactly the same the only difference is the turbine. Is vaportrail the one who had a shop in florida who tuned a Silvia with the 3040R?
Old 03-07-2005, 01:26 PM
Smarter than you
DIRep972's Avatar
yep, sure is.
Old 03-07-2005, 01:30 PM
Mikes01GSR's Avatar
He got that GT3040R for that car right before mine, wonder why he didn't go GT35R for that car then...things that make you go hmmm......I believe he was building a bad *** civic also, which I purchased my RPS Carbon / Carbon clutch from him.
Old 03-07-2005, 01:33 PM
done's Avatar
mod can you clean this up, i want this to be a tech article!!!!!
i want some answers
STAY ON TOPIC
Old 03-07-2005, 01:36 PM
Mikes01GSR's Avatar
Sorry Jordo I apologize. Up for info.
Old 03-07-2005, 03:25 PM
BoostR41's Avatar
my friends 240 had a 3040 on it. the car trapped at 127mph on et streets with a street tune. obviously I don't have a dyno # to back it up but I am sure that turbo car do 600whp. his car weighes about 2800-3000lbs and like I said that was a street tune at 24psi.
either way I like the GT35R the way the power bands look. and a BB turbo will always spool faster than a non BB turbo of close to the same specs
Old 03-07-2005, 04:32 PM
Mikes01GSR's Avatar
Default Re: Compare t3/67 vs gt35/40r vs gt3040 (BoostR41)
Well let me state this, my GT3040R has the .63A/R turbine maybe he has the larger one. Mine might be able to do 600whp but it would be at the very edge of it's efficiency range.
Old 03-09-2005, 06:08 PM
done's Avatar
anybody?
Old 03-09-2005, 06:46 PM
SEFIxCivic's Avatar
im ordering a GT35R t4 tomorrow. i'm going to test it against my pt67 h cover t4. i'll be sure to post the results.
Old 03-09-2005, 11:38 PM
Better than steak
Arturbo's Avatar
Default Re: Compare t3/67 vs gt35/40r vs gt3040 (SEFIxCivic)
I will say that a certain SFWD car (b18c) made 622whp 499ft.lbs with the GT35R. Its not me so don't ask..lol. I wont say how much boost either. I'll see if I can get the dyno.
Old 03-09-2005, 11:47 PM
Mase's Avatar
Default Re: Compare t3/67 vs gt35/40r vs gt3040 (Arturbo)
500 ft/lbs, it has to be over 30 psi
Old 03-09-2005, 11:48 PM
Better than steak
Arturbo's Avatar
Default Re: Compare t3/67 vs gt35/40r vs gt3040 (Mase)
C16 and over 30psi.
Old 03-09-2005, 11:58 PM
SiRkid's Avatar
iirc they got the 3040 thinking it was the 35r but dude selling the turbo(Extreme boost) didnt know what he was selling as they were very new at the time. Not much info was availible yet. i have the same turbo as they do/did.
id go for the 35r if spool times would be the same but i imagine some difference in the spool time(slightly longer for the 35r )but i could be wrong.
Old 03-10-2005, 12:55 AM
V-SPEC 1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">I will say that a certain SFWD car (b18c) made 622whp 499ft.lbs with the GT35R. Its not me so don't ask..lol. I wont say how much boost either. I'll see if I can get the dyno.</TD></TR></TABLE> was this made from a t4 or t3 Art?? what A/R. thanks.
Vic
Old 03-10-2005, 12:59 AM
Better than steak
Arturbo's Avatar
Default Re: Compare t3/67 vs gt35/40r vs gt3040 (V-SPEC 1)
T3 not sure on the AR tho.
Quick Reply: Compare t3/67 vs gt35/40r vs gt3040
