Better Turbo for b18C1?
So i am beginning to put together a turbo set up for my 00 GSR. i am not wondering which would be a better turbo. Im going to buy it from Cheapturbo.com. I would like the pros and cons on each of the turbos such as lag and power....etc if possible on my particular set up. There are Turbo GODS on HT and i was wondering if anyone could help make my decision easier! Thanks In Advance!
Heres the 3 i was thinking!
GARRETT T3/TO4E 50 TRIM W/ .63 A/R
COMPRESSOR SPECS:
flow: 46 lbs/min 588cfm
50 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
GARRETT T3/TO4E 57 TRIM W/ .63 A/R TURBINE
COMPRESSOR SPECS:
flow: 50 lbs/min 640cfm
.60 A/R HOUSING
57 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
GARRETT T3/TO4E 60 TRIM W/ .63 A/R TURBINE
COMPRESSOR SPECS:
flow: 53 lbs/min 678cfm
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
Also open to other suggestions....preferably on garrett T3/T04E
I appreciate it!
COMPRESSOR SPECS:
50 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
COMPRESSOR SPECS:
.60 A/R HOUSING
57 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
COMPRESSOR SPECS:
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
I appreciate it!
Re: Better Turbo for b18C1? (pgpunkguy)
ok great thanks....but eventually i would like to hit 350whp with some block work....but for now i will jsut stay at prolly low psi....i mean they are the same price? does any one spool faster? i want it to spool low....but also be able to make power later
Re: Better Turbo for b18C1? (Hulkmanj99)
COMPRESSOR SPECS:
.60 A/R HOUSING
57 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
I have this one on my pretty stock GSR motor. In my opinion it spools up a little late for daily driving. I get full boost by about 4700 rpms. I am switching the compressor housing for a .48 to spool up faster. Should resond better for a daily driver.
That turbo has a NASTY top end though. But personally I would go with something slightly smaller for a daily driver. The smalller turbo will still support 350 horses easy.
COMPRESSOR SPECS:
.60 A/R HOUSING
57 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
Re: Better Turbo for b18C1? (mike1114)
ill will probably end up goin with this one...just cause you aid it might spool a little quicker and it would easily support 350+ whp....but it wont make as much power as the other 2 corect? but it will spool lower? how much is the difference in power on them?
COMPRESSOR SPECS:
50 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
COMPRESSOR SPECS:
50 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanojp1 »</TD></TR><TR><TD CLASS="quote">i have the 57 trim, .63 housing...dyno numbers coming soon...</TD></TR></TABLE>
But where do you start to spool or boost at? i would like to be in the 4000 range, but still be able to make enough power later on without having to switch **** on the turbo. and i dont exactly know the difference in power between these turbos or pros and cons
The 50 trim will be fine for 350whp. No reason to go bigger. I have the 57 trim on my b18c, and I am happy with it. I would like a little better spool, but I think it is good now because it is hard to get traction as is.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hulkmanj99 »</TD></TR><TR><TD CLASS="quote">But where do you start to spool or boost at? i would like to be in the 4000 range, but still be able to make enough power later on without having to switch **** on the turbo. and i dont exactly know the difference in power between these turbos or pros and cons </TD></TR></TABLE>
I start to spool in the 3000 range. Full boost in the 4000 range.
If you want a quicker spool just remember to get a large dp like 3", and use something like 2.25" IC piping, and an EBC helps too.
Re: Better Turbo for b18C1? (HXMan)
so now im just debating between 57 and 50 trim? I plan on doing a 3" DP and definately like 2.25 MINIMUM IC piping. But im leaning towards the 50 trim because people are saying it will spool lower and still creat great power. So thats what i think im going to do, 57 trim becase he says his spools in the 3000 range with full boost in 4000 which is what i want....and i think its a little more capable of creating more power!....but keep em coming on what you have and why you like it.
i am going to CheapTurbo on friday to pick up a T3/T04E 57 trim .63 A/R!! hope to make good power....especially with Alex's (toyosupr) manifold!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hulkmanj99 »</TD></TR><TR><TD CLASS="quote">i am going to CheapTurbo on friday to pick up a T3/T04E 57 trim .63 A/R!! hope to make good power....especially with Alex's (toyosupr) manifold!! </TD></TR></TABLE>
I got same Size, but with a Turbonetic. Start spooling at 3,2oo rpm Full Boost around 4,ooo rpm... ( Been leaking somewhere lately )...
Good choice though.
Good choice though.
Re: Better Turbo for b18C1? (synik)
Thanks mang!! I hear turbonetics isnt all that good case they leak alot? i dunno....but alb. NM....haha good times of being **** *** drunk on the way to arizona from illinois!!! haha
i got the .57 trim and o man is it fun. it is very hard to get traction in first gear and when boost hits in first it takes like .1 seconds for the rpms to jump from 4000 to 8000. so i personally try to avoid racing at lights but damn it ******* pulls in every gear. i hit 290whp @9psi on stock b18c1 block. cant wait to upgrade internals and hit around 350. u should be happy with it.
Re: Better Turbo for b18C1? (donkiman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donkiman »</TD></TR><TR><TD CLASS="quote">i got the .57 trim and o man is it fun. it is very hard to get traction in first gear and when boost hits in first it takes like .1 seconds for the rpms to jump from 4000 to 8000. so i personally try to avoid racing at lights but damn it ******* pulls in every gear. i hit 290whp @9psi on stock b18c1 block. cant wait to upgrade internals and hit around 350. u should be happy with it. </TD></TR></TABLE>
That just brought a smile to my face!!
underpressure02
02-10-2004 07:26 AM
