b18c1 drivability issue
Old 02-05-2010, 10:14 AM
98jdmcivic's Avatar
Default b18c1 drivability issue
Recently my car started to randomly sputter. I would pull up to a stop light and it would try to die, I have to keep my foot into the throttle a little bit to keep it running. It doesn't do it all the time, it has been more frequent recently and now i just don't want to drive it. When it does die, it is hard to start again. Any suggestion.
Old 02-05-2010, 10:23 AM
AbitAvenger's Avatar
Default Re: b18c1 drivability issue
Need to post way more info.
Whats the setup? Is it tuned?
Old 02-05-2010, 10:27 AM
GsrIntegra789's Avatar
is the car tuned? it can be either running too lean or rich at idle. Your IAC could be clogged. Your map sensor could be taking a S%&T. etc...
Old 02-05-2010, 10:28 AM
With it being intermittent I'm thinking electrical
Old 02-05-2010, 10:34 AM
^ yup, thats why i think its possible the MAP is going bad.
Old 02-05-2010, 10:39 AM
98jdmcivic's Avatar
My bad for the mystery post, the car is tuned, and was running great, 10 lbs of boost forged internals, solid engine. I have just been a bit stumped on the current issue. It doesn't really do it when it is cold, but after warm up it does.
Old 02-05-2010, 10:42 AM
by any chance have you done a valve lash adjustment recently?
Old 02-05-2010, 10:44 AM
98jdmcivic's Avatar
not in a few years, lets say 15,000 miles (exaggerated).
Old 02-05-2010, 10:45 AM
98jdmcivic's Avatar
Would a compression test give me an idea of the valve train?
Old 02-05-2010, 10:51 AM
trini-gsr's Avatar
i had the OPs same problem and it was an issue with the MAP sensor. difference was when mine cut off, i could start it right back again. it would just idle way too low at stops intermittently and cut off unless u were giving it a bit of gas.
you might want to check the MAP sensor out...
Old 02-05-2010, 10:55 AM
98jdmcivic's Avatar
I will check it out. thanks.
Old 02-05-2010, 11:30 PM
jasoncrashtech's Avatar
i would look into the distributor also. sounds like a spark problem maybe.
Old 02-12-2010, 05:11 AM
98jdmcivic's Avatar
I am leaning towards the ignition issue, when it starts missing the tach goes a little crazy.
jdm95
Engine Management and Tuning
02-02-2010 08:10 PM
fatboy1185
32
09-23-2008 07:37 AM
PINKS
05-23-2006 04:10 PM
kaj
02-20-2006 04:38 PM
dustin
06-19-2002 07:36 PM
Quick Reply: b18c1 drivability issue
