anyone running double stacked headgaskets??
a friend of mine is putting together a b20/vtec with a gsr head currently. if the block is the b20z the compression will be around 10:1, which is too high for my tuning comfort on a b20. is anyone running 2 headgaskets on their turbo b series?? im seriously contemplating having him use 2 gaskets to lower static compression and buy us some safety wiht peak cyl pressures under boost.
Guest
Posts: n/a
Re: anyone running double stacked headgaskets?? (urbansi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi »</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
any experience or just being a douche?
Ive done it and never had a problem..just popped the rivits out and layer'ed them down
Re: anyone running double stacked headgaskets?? (jdmhonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmhonda »</TD></TR><TR><TD CLASS="quote">why would you think thats too high?</TD></TR></TABLE>
b20's are notorious for blowing sleeves, and im just trying to start with a lower compression in efforts to keep the peak cylinder pressures and hopefully prolong the lifetime of the motor. yes the compression is still less than a jdm b18c, but the motors are constructed differently, so i dont think they are accurately comparable.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brett Roger »</TD></TR><TR><TD CLASS="quote">Lots of Euro tuners do it, seems to work ok on VW's, but it's definately one of those iffy things. Worse comes to worse you're gonna blow out HG's more easily.</TD></TR></TABLE>
yes, which is where i got the idea. my very good friend has been running double headgaskets on his 2.0 x-flow turbo for like 3 years on an fmu and his car runs smooth as any other turbo car ive been in. this motor will be using arp headstuds as well
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 »</TD></TR><TR><TD CLASS="quote">
Ive done it and never had a problem..just popped the rivits out and layer'ed them down </TD></TR></TABLE>
thank you. this is the type of response i was looking for
Re: anyone running double stacked headgaskets?? (vaporboy12)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vaporboy12 »</TD></TR><TR><TD CLASS="quote">just dont run alot of boost</TD></TR></TABLE>
planning on running around 6 psi, definately no more than 8. should be in the 250 whp range with those boost figures, which is fine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by urbansi »</TD></TR><TR><TD CLASS="quote">holy **** 6 PSI you better make that 4-5 gaskets, just to play it safe!!!! </TD></TR></TABLE>
please do not post in any of my threads.
Re: anyone running double stacked headgaskets?? (blackeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackeg »</TD></TR><TR><TD CLASS="quote">
please do not post in any of my threads.</TD></TR></TABLE>
look at his sig, dont worry about him... seriously.
a friend informed me that Mr. Gaskets sells a stackable headgasket kit... i'm not sure if theyre available for hondas tho.
good luck.
and b20s crack sleeves b/c theyre 84mm (less material when compared to 81mm) and i beleive they are a different material.
good luck.
how about this, i'll post at any thread that i like and you can eat me. sound good you communist, take a ******* joke.
Re: anyone running double stacked headgaskets?? (nerdsports)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nerdsports »</TD></TR><TR><TD CLASS="quote">
and b20s crack sleeves b/c theyre 84mm (less material when compared to 81mm) and i beleive they are a different material.</TD></TR></TABLE>
i did a few hours reading up on it the other day. i guess they are prone to cracking where the cylinders meet each other, kinda in the corners of the cyls.
the owner is probably going to rebuild the gsr block that blew, and is just using this b20 for the summer.
i was just kinda curious if anyone does this on hondas, cause as mentioned before volkswagon does it on occasion
how about this, i'll post at any thread that i like and you can eat me. sound good you communist, take a ******* joke.</TD></TR></TABLE>
actually, how bout this: continue to be a dick, ill dock points.
useless **** is not needed in threads. this forum is bad enough, dont make it anyworse
Re: anyone running double stacked headgaskets?? (Mase)
ok useless information i understand. i have had a personal expierence with stacking head gaskets on a b18c1.
my friend had a turbo rebuild done at a reputable shop outside of chicago, he decided to try stacking head gaskets to lower the compression a little and ended up being more work and bullshit than the origional idea.
come to it 3 weeks after the install of the head gaskets they blew.
he tried it again from a different brand, same place installed it, blew again.
for some reason he tried it one more time from the dealer he thought he should have gone to in the first place, installed, next day blew. you could say the motor is screwed, but it wasnt. everything that was tested on the car was fine, and the only thing it led back to was the head gaskets.
so many head gaskets later and tons of money wasted he ended up going with an OEM gasket, and 3 months later hasn't run into a single problem. i understand that we are talking about a different motors here, but i still think my input is hardly useless. just my .2
what you just said is not useless, its first hand and thats what i am looking for.
sorry to hear your friend had to go through all that
IF the owner decides to do something to try to lower his compression, im thinking it might be better just to get a thicker aftermarket gasket, like a greddy or something
dblock2x
15
01-10-2007 05:44 AM
existanzcivicb20
60
10-13-2006 10:54 PM
