using eclipse mani to turbo f22b2
Old 06-21-2008, 11:35 AM
abc17abc's Avatar
Default using eclipse mani to turbo f22b2
ok i have a f22b2 in my 94 accord. im thinking about turboing it (i want to do it as cheap as possible) so i heard about using setups from eclipses. i have alot of questions and i appreciate ANY help. thanks
IM NOT LOOKING FOR 999LBS OF BOOST, MAYBE 6-8PSI
1. what i need to know is what years work?, gst, gsx? and will the downpipe work?
2. should i use the stock turbo? what other turbos bolt up to the eclipse mani? whats best for my motor (i know too small is bad)
3. will it all fit? i dont care about a/c
4. im not a genius so im a little confused, if i use the stock turbo does it already have a wastegate? is it internal? if i get a diff turbo what do i do about the wastegate?
5. what do i need beside the mani, turbo, downpipe, bov, dump valve, intercooler, pipes?
from what i know it is good to get:
better fuel pump
450cc injectors
better fuel rail
better ignition system
better 02 sensor
missing link
what above is NEEDED, do i need all this for 6-8lbs of boost? what else did i forget?(i only want to get what i need)
6. can someone explain fpr's and fmu's, if i need them, do universal ones work easily, what exactly do i adjust to change my boost?
7. what about oil lines and stuff, what do i need to do?
8. if i put a missing link in do i need ecu work? (remember im only doing like 6-8lbs)
9. will i have to upgrade my radiator or get a more powerfull fan?
again i am a noob so i need help, i appreciate this alot, thanks
p.s., how much hp/tq would i expect from this setup?
Modified by abc17abc at 1:06 PM 6/21/2008
Modified by abc17abc at 2:05 PM 6/21/2008
Old 06-21-2008, 09:45 PM
HiProfile's Avatar
Default Re: using eclipse mani to turbo f22b2 (abc17abc)
The DSM manifold only works on F22Ax (ex. dohc vtec) engines, the others have odd port spacing.
So 90% of your post was wasted time
Old 06-21-2008, 11:01 PM
abc17abc's Avatar
yea mine is 0--0-0--0 and f22a* is 0-0-0-0... research helps.... anyways will the f22a* head fit the f22b* sohc? because i know you can put a h23 head on a f22a*, but couldnt find anything on the f22b*...
Modified by abc17abc at 1:13 AM 6/22/2008
Old 06-22-2008, 06:05 AM
Adriano's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">So 90% of your post was wasted time </TD></TR></TABLE>
Why wasted time? He had a question and he took the right step and asked a question.
Adriano
leoverte
04-11-2007 05:36 PM
Cypher0117
12-12-2005 05:42 PM
mac_24_seven
05-06-2005 01:14 PM
bdicustoms
08-09-2003 06:44 PM
turboex
08-03-2003 10:03 AM
Quick Reply: using eclipse mani to turbo f22b2
