***Forced Induction Forum FAQ***
Old 05-30-2008, 04:02 PM
  #26
H-T Administrator
Clayton's Avatar
Default ***Forced Induction Forum FAQ***
Info on Garrett BB turbo's not being rebuildable. BE CAREFUL buying used BB turbos
https://honda-tech.com/zerothread/2311400
Clayton is online now
Old 06-29-2008, 11:18 PM
  #27
ABL 2 FLY's Avatar
bump
ABL 2 FLY is offline
Old 07-04-2008, 11:38 PM
  #28
pcguy760's Avatar
Default Re: (ABL 2 FLY)
VERY Informative Honda/Acura turbocharging guide :
http://beesandgoats.com/boostfaq/g2icturbo.html
pcguy760 is offline
Old 08-18-2008, 06:43 PM
  #29
zccrx's Avatar
Default Re: (pcguy760)
i know im not supposed to post but here is a suggestion can some one organize a reply with all the official thread like ( turbo on my ef) (official ls-vtec turbo thread) etc... i cant seem to find the ef turbo thread and i think its a good idea.
zccrx is offline
Old 09-20-2008, 05:45 PM
  #30
vinceg143's Avatar
can the guild also be used for integras older than 93
vinceg143 is offline
Old 11-30-2008, 07:54 PM
  #31
acuraturbo90's Avatar
Default oil
hello i have a Q what type or brand can i used in my b16 turbo lmk asap pls thank i used before royal purple and they told the are not good ? any help pls
acuraturbo90 is offline
Old 12-16-2008, 01:07 PM
  #32
jdmdc2boi12's Avatar
wow good info's
jdmdc2boi12 is offline
Old 12-16-2008, 02:11 PM
  #33
6000pounds's Avatar
turbo install http://coolazz.tripod.com/turbo.html http://home.attbi.com/~jeffrich/
not a working link
6000pounds is offline
Old 02-02-2009, 09:50 PM
  #34
gofast300@gmail.com's Avatar
Default Re: ***Forced Induction Forum FAQ***
where can i get a vacume diagram for turbo gsr
gofast300@gmail.com is offline
Old 02-03-2009, 04:49 PM
  #35
starbai's Avatar
i'm a complete turbo noob so dont flame too much... but are any of the links above (i'm skimming through them now and will read them in more detail later) good for describing what things should be done to build a motor right to handle high boost reliably?
i almost need **** broken down to a retarded level beacuse i literally know nothing and i'm reading everything i can get my hands on TO learn.
starbai is offline
Old 02-08-2009, 10:01 AM
  #36
Axix24's Avatar
is it common for a brand new garrett gt turbo have blue smoke at idle at times? Engine is fine, return fitting is mounted on top of pan. Would a oil feed restrictor plate help??
Axix24 is offline
Old 03-11-2009, 05:31 PM
  #37
Mr. Badwrench
boostedcivicsir's Avatar
skunk2 pso 1's vs. ctr cams:
https://honda-tech.com/forums/forced-induction-16/dyno-comparison-skunk2-pro-1s-vs-ctr-camshafts-2520138/
boostedcivicsir is offline
Old 04-04-2009, 09:49 AM
  #38
RIW1314's Avatar
CAN ANYONE help with how/where to tap in to run coolant lines to water cooled turbo on a B18c PLEASE!!!!!????????????
RIW1314 is offline
Old 04-18-2009, 08:14 AM
  #39
Phantom Integra's Avatar
i have a ls-v hi cr. 11.2:1 and blox spec b cam. i change my mind at the last min. to go boost. how much boost can i boost and power can i make on e85 fuel
Phantom Integra is offline
Old 04-23-2009, 10:42 PM
  #40
JarteroB16's Avatar
Really good Info...
JarteroB16 is offline
Old 05-21-2009, 11:26 AM
  #41
fast2camciv's Avatar
https://honda-tech.com/forums/showth...ghlight=holset
the holset turbo thread should be under the faq IMO...
fast2camciv is offline
Old 07-01-2009, 10:36 AM
  #42
jcblessing21's Avatar
i am needing rings for my d16y8 0.020 bore 75.5mm CP pistons 9.0:1 cr. the nrp rings are too thick for these pistons. anybody know where i can get the rings at ?
jcblessing21 is offline
Old 07-13-2009, 08:13 PM
  #43
New User
Awinner's Avatar
Great Info, clears up the SC vs. TC
Awinner is offline
Old 02-19-2010, 06:21 AM
  #44
ken9's Avatar
Thank.. I will be checking
ken9 is offline
Old 04-12-2010, 09:00 PM
  #45
nfamousdevil's Avatar
damn, thats a lot of info.
nfamousdevil is offline
Old 04-21-2010, 07:17 AM
  #46
Crex167's Avatar
great thread
Crex167 is offline
Old 07-07-2010, 10:46 PM
  #47
LsDecepticon's Avatar
anyone have anything on oil temperatures here? or normal oil pressure?
LsDecepticon is offline
Old 08-19-2010, 06:10 PM
  #48
Mr06CivicSi's Avatar
what is the cheapest turbo kit for a 06 honda civic si?
Mr06CivicSi is offline
Old 11-17-2010, 06:29 PM
  #49
Droolin's Avatar
My mind is going to explode with all the info on here.. Now if I could only retain all that info at once.
Droolin is offline
Old 12-02-2010, 08:05 PM
  #50
thelittlevoices's Avatar
OK im not exactly sure where to post this and as i am new and cant start a thread that i think here is a good place to put it. I have a 90 Integra LS and I just came into a Garret T3 turbo....just the turbo. it needs a waste gate acuator and EVERYTHING else. As I have never realy worked on turbos installed them I need help. I need to know what I need to get it up and running and some direction on where to get the parts on the cheap if at all possible if anyone could PM me with ANY help i would be totaly greatful. Also I have a 88 civic hatch with the swapout i want to turbo but again need some direction.
thelittlevoices is offline
Quick Reply: ***Forced Induction Forum FAQ***
