***The Official JRSC Thread***
Old 02-28-2006, 07:34 AM
  #2551
rmcdaniels's Avatar
Default Re: (Veris)
Here's the Pulleyboys (http://www.pulleyboys.com) 3.2" pulley; it came in this morning. It's shiny on the edge because they are all 7-rib pulleys and I cut off the extra ribs because it's too close to the shock tower with the extra ribs.
Old 02-28-2006, 08:20 AM
  #2552
daveb91's Avatar
Default Re: BLOWER RPM (STREETWERKZ)
"None of this is exact science...its just close to what it should be.
The bright side is that there are many possibilities "
kinda hard for us D series guys. </TD></TR></TABLE>
Well true unless like me you have a A6 then everyother newer d series has a bigger crank pulley. Used a z6 pulley now I am running a y8.
Old 02-28-2006, 09:10 AM
  #2553
Veris's Avatar
Default Re: BLOWER RPM (daveb91)
If you D series guys want I can run your pulley sizes through my calculator.
You'll need to provide me with max engine rpm and blower/crank pulley sizes.
Old 02-28-2006, 09:19 AM
  #2554
BiG Chris's Avatar
My A6 is running the crank pulley supplied from JR for the EK kit and im running the stock 3.4 crx snount pulley yielding 8psi at 4500 redline at 7k rpm my next motor im buiding will be better and i hope to have the same crank pulley and a 3.2 endyn pulley to get 10 psi.
On the other hand the cobra mustang guys are spinning thier blowers to 25k rpm
Old 02-28-2006, 10:38 AM
  #2555
elpiar's Avatar
Default Re: (BiG Chris)
Where can I buy Kamikazee header? Anyone?
Old 02-28-2006, 10:42 AM
  #2556
Timmay's Avatar
Default Re: (elpiar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elpiar &raquo;</TD></TR><TR><TD CLASS="quote">Where can I buy Kamikazee header? Anyone?</TD></TR></TABLE>
http://www.kamikazeperformance.com/store/shop/
Old 02-28-2006, 12:34 PM
  #2557
hinds90's Avatar
Default Re: BLOWER RPM (Timmay)
Anybody know a ballpark figure on how much the lht intercooler setup cost.
Old 02-28-2006, 12:55 PM
  #2558
rmcdaniels's Avatar
Default Re: BLOWER RPM (hinds90)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hinds90 &raquo;</TD></TR><TR><TD CLASS="quote">Anybody know a ballpark figure on how much the lht intercooler setup cost.</TD></TR></TABLE>
$1000 for the manifold modification, then you need a pump, heat exchanger, reservoir, coolant lines/fittings, figure $1300-$1500 for a whole new setup.
Old 02-28-2006, 03:25 PM
  #2559
civicandy's Avatar
Default Re: BLOWER RPM (rmcdaniels)
is that lht cooler an air/water cooler? i am looking at the jrsc for my 90 hatch with b16a. i am concerned about the extra heat. fyi, i do run a DA radiator.
Old 02-28-2006, 03:45 PM
  #2560
Timmay's Avatar
Default Re: BLOWER RPM (civicandy)
radaitor has nothing to do with blower heat
Old 02-28-2006, 04:22 PM
  #2561
rmcdaniels's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicandy &raquo;</TD></TR><TR><TD CLASS="quote">is that lht cooler an air/water cooler? i am looking at the jrsc for my 90 hatch with b16a. i am concerned about the extra heat. fyi, i do run a DA radiator. </TD></TR></TABLE>
http://www.lhtperformance.net/....html
Old 02-28-2006, 06:47 PM
  #2562
xerox445's Avatar
Probly been answered before, but has anyone looking into getting a whipple mounted to a b-series? I know they dont make CCW units, but im shure someone could fab up a gear or something for it to reverse the belt drive.
Old 02-28-2006, 06:50 PM
  #2563
pumpkinkidd's Avatar
I'm trying to my replace stock pulley with a 8psi pulley but i'm having a little trouble. I was able to get the nut off but the pulley just won't come off. Any help would be great.
pk
Old 02-28-2006, 06:55 PM
  #2564
Jaker's Avatar
Default Re: (pumpkinkidd)
Gently warm up the pulley with a propane torch. It becomes pressed onto the shaft over time, and can be dificult to remove without a puller. A little heat will expand the aluminum pulley enough that it should come right off. You won't need alot of heat, and if you do overheat things, you could melt/burn the shaft seal, so be careful.
If you don't have propane, the oven set on lowerish heat setting (200 degrees) will heat it enough to get it off.
Old 02-28-2006, 06:57 PM
  #2565
Right on, I'll give that a try. thanks!
pk
Old 02-28-2006, 07:01 PM
  #2566
rmcdaniels's Avatar
Default Re: BLOWER RPM (xerox445)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xerox445 &raquo;</TD></TR><TR><TD CLASS="quote">Probly been answered before, but has anyone looking into getting a whipple mounted to a b-series? I know they dont make CCW units, but im shure someone could fab up a gear or something for it to reverse the belt drive. </TD></TR></TABLE>
I tried it with a Whipple 1200AX. It was a pain in the *** and I couldn't get a setup together that I was confident wouldn't fly apart at 15000 RPM. It was a brand new blower and cost a bunch of $, so I didn't want to try reversing the nose assembly for fear of ruining the resale value. I eventually sold it to some guy in New Zealand to put on his Hayabusa. I'm trying it now with a $100 M90 that I don't care if it gets destroyed, so I may revisit it if that works out or if I can find a cheap used Whipple, but they go for big $, even on ebay.
Lysholm compressors also have a drawback related to their design. They compress internally, so they can't be bypassed to unload them.
Old 02-28-2006, 07:06 PM
  #2567
xerox445's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rmcdaniels &raquo;</TD></TR><TR><TD CLASS="quote">
Lysholm compressors also have a drawback related to their design. They compress internally, so they can't be bypassed to unload them. </TD></TR></TABLE>
And thats why the mercedes and such have an electromagnetic clutch on the blower....I understand now.
What would you need to do, put a "BOV" on the manifold?
Old 02-28-2006, 07:16 PM
  #2568
rmcdaniels's Avatar
No, you'd still bypass it to kill the boost, but the blower would still be compressing, using a lot of HP to turn, and generating heat. People do it all the time (see Kenne Bell kits for an example), it's just not efficient.
Old 02-28-2006, 07:18 PM
  #2569
xerox445's Avatar
oh i gotcha.
Old 03-01-2006, 12:17 AM
  #2570
jdmsiR20's Avatar
read up to page 6 and will continue to do so little by little until im done....
got a little dillema...
i've got a 94gsr with the usual i/h/e/cams, clutch, etc etc.... and it is satisfying to a point. i dont want this car to turn into my full out race machine, as im buying another hatch in a couple years once im out of college. in the past month, my cousin, brother and friend all picked up newer cars -- a wrx, s2k, and an evo.... simply, im left in the dust...
im kind of just looking for kind words on a JRSC setup to keep my entertained until then. looking to run mid 13's, no more than 240whp... it is daily driven 250miles per week, and 105xxx miles on the OG motor... compression is 220psi, exactly, on all cylinders...
kind of just want to bolt up the charger, get it tuned, and carry on. tired of buying n/a parts that net me a 14.5 1/4 time.... also dont want to deal with the complication of a turbo setup....
the JRSC is for me..... right?
Old 03-01-2006, 04:22 AM
  #2571
Gojira D.O.T's Avatar
any updates on the m90 reengineering
Old 03-01-2006, 06:21 AM
  #2572
rmcdaniels's Avatar
Default Re: (Gojira D.O.T)
Wynn should have it now, I Fedexed it to him last week. I don't want to rush him on it, but I'll send him an e-mail to make sure it arrived okay.
Old 03-01-2006, 01:36 PM
  #2573
funky_cornbread's Avatar
Default Re: BLOWER RPM (jdmsiR20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmsiR20 &raquo;</TD></TR><TR><TD CLASS="quote">read up to page 6 and will continue to do so little by little until im done....
the JRSC is for me..... right? </TD></TR></TABLE>
It is right for you. 3" intake of some kind, Kamikaze header, test pipe, 2.5" exhaust, engine management of some kind, bigger injectors, walbro fuel pump, cam gears, LSD of some sort, port the s-tube, MVM stepper pulley, hondata IM gasket, water wetter, 160 JR thermostat, and a damn good tune and you'll hit your mark.
the JR was made for the b18c.
Old 03-01-2006, 03:28 PM
  #2574
Hazeburner's Avatar
Ok, im getting the new SI within the next 2 weeks. I hear its quick but what, high 14's if im lucky? Stock is 11-1 compression. You guys think i can slap a JRSC on that bitch?
Old 03-01-2006, 08:25 PM
  #2575
purehonda's Avatar
Default Re: (Hazeburner)
comptech is already making one for new si, if they havent completed it yet.
Quick Reply: ***The Official JRSC Thread***
