Stalling motor when A/C turned on after being tuned w/ aem 3010
I have 99 honda accord manual tranny f23a1, it is turbo charged with the list below. my car was tuned without the a/c on, so now when i turn on the a/c my accord will stall out coming to stops mainly, if it idles long enough it will stall too. i had a base map on the engine before the tuning and didnt have this problem. so i know it was becasue of the person who tuned the motor without a/c on. everything else is running fine, would a aem genius look at my basemap and see if they see a easy fix? or anyone know of this problem? i post a link to it after work if aomeones willing to help. thanks.
*also the tuner will not take my car back and fix the issue
Re: Stalling motor when A/C turned on after being tuned w/ aem 3010 (accord99power)
Shady tuner huh, where did you find him?
Any luck yet? Is the A/C compressor locked up? I know simple yet easy question.
Re: Stalling motor when A/C turned on after being tuned w/ aem 3010 (sportsterguy3421)
This is a common issue with AEM ems.
The only real way to resolve it is to take the car to a tuner.
You can try playing with a couple of settings such as
AC min speed
AC on delay
AC load comp
To find these options click on setup, then click on a/c then click on options.
AC min speed
AC on delay
AC load comp
Re: Stalling motor when A/C turned on after being tuned w/ aem 3010 (mtber)
heres he base map have any idea what i would set it to?
http://members.***.net/nitemar...9.cal
any help would help! its a long story the guy is in niceville,fl.
a/c on delay= .39 s
a/c min speed- 500 rpm
load comp=5.47%
these are the values i have right now, anone have any suggestions?
load comp=5.47%
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord99power »</TD></TR><TR><TD CLASS="quote">a/c on delay= .39 s
load comp=5.47%
these are the values i have right now, anone have any suggestions?</TD></TR></TABLE>
Change the load comp to 15-20 %
Change the a/c min speed to 650 rpms
change the a/c on delay to 3 secs
load comp=5.47%
the idle a/c load made a big difference no stalling yet, however 15% was to high i set it to about 10.16 i had seen on another base map. but you solved my problem so far thanks!
94svtec
04-27-2005 04:26 PM
