De-pin an obd1 to obd2 jumper harness...
Old 01-27-2010, 08:23 AM
MARVNVRAM's Avatar
Icon2 De-pin an obd1 to obd2 jumper harness...
Is it possible to de-pin the wires on the jumper side (not the ecu side connectors). I was looking and made an attempt but they are pinned a different style. The connector block isnt like OEM connectors where you can push down a tab and slide out the wire. It looks as if its a fixed opening where the terminal slides and "snaps in". Just wondering if it is possible, TIA.
Old 01-30-2010, 08:26 AM
Blown90hatcH's Avatar
Default Re: De-pin an obd1 to obd2 jumper harness...
So you want to remove a pin on the ECU block side.....not the side that plugs into the ECU, but the female side that receives the underdash ecu plugs?
If so, those pins pull outward....like pull from the female side. So if the wires are still soldered in on the otherside from the ecu plugs....not going to happen.
efhondaracer27
05-31-2010 01:56 PM
hfrex
07-16-2009 07:05 AM
Touge Tuning
06-06-2005 09:04 AM
4drb18ek
03-01-2003 07:42 AM
216.226.142.95:27016
01-08-2003 11:45 AM
Quick Reply: De-pin an obd1 to obd2 jumper harness...
