car wont rev past two-step
ok i ordered a chip for my ls/vtec eg coupe from phearable.net with a two-step launch rpm of 4000rpm. after installation of chip i go for test drive n car wont rev past two step when going down the road. i have no check engine light on so what could be the cause of this??
Re: car wont rev past two-step
i tried that it said email for tech questions so i did and im waiting for an answer from them, just thought i would see if anyone else could help me sooner. and its good info for future reference if it gets answered correctly...
The basic 2-step is speed based, which means your VSS sensor signal is not reaching the ECU properly either because of the sensor itself or the wiring.
It doesnt necessarily mean that the VSS sensor is bad. Alot of times I've found the pins to be corroded for the VSS plug. I usually just cut a spare pigtail of another harness and soder it in and all is good. Its usually the middle pin that is the worst. Which if memory serves me right is the 12v power too the sensor.
vss was same one that was working on the d series in the car before i swapped in the ls/vtec so thats why i didnt think that was causing it. n my speedo still works fine, could it still be the problem?
To get technical support all you had to do is go to http://www.phearable.net & click on contact.
If you are having issues with your vehicle not being able to exceed the 2 step rpm you need to do the following:
1. Check your codes.
2. Check to see if a speed signal is being reported to your ecu.
The ecu needs to see a vehicle speed before it will allow the vehicle to exceed the 2 step rpm.
Let me know if I can answer any other questions.
ok i swapped the ecu out with the one from my b20vtec hatch but still used the phearable chip for the ls/vtec and it worked perfectly so i guess i just bought a bad p28? thanks for everyones help, phearable basemaps are awesome! second car ive run one on and both perform flawlessly.
when i use my ecu outta my other car (b20vtec) with this chip in it (ls/vtec) it revs like it should but idles erratic, when i use this chip in the p28 it idles fine but wont rev past twostep and runs pretty terrible (bad ecu), so now i chipped my po6 but did not convert it to vtec yet and it idles fine n runs great but i cant rev past two step again. y would the vss signal make it through to b20vtec ecu but not to the other two? is it because the po6 isnt converted to vtec yet?
Mauro87
13
07-15-2012 05:16 AM
4genciv04
04-28-2009 12:15 PM
