VAFC wiring diagram for OBD0 CRX?
Old 12-05-2003, 02:35 PM
CHRIS 1.8's Avatar
Default VAFC wiring diagram for OBD0 CRX?
Does anyone have the VAFC wiring diagram for a OBD0 CRX running a PR3 ECU?
Old 12-05-2003, 02:59 PM
Blown90hatcH's Avatar
Default Re: VAFC wiring diagram for OBD0 CRX? (CHRIS 1.8)
Vtec solenoid(Purple/Pink wires) = A8 location
Pressure signal(Yellow/White wires) = D11 location
VTM signal(Blue wire) = B5 location
Throttle signal(Gray wire) = D7 location
RPM signal(Green wire) = B15 location
Ground(Black/Brown wires) = A16 location
IG Power(Red/Orange wires) = A15 location
Enjoy
Old 12-06-2003, 09:40 AM
CHRIS 1.8's Avatar
Default Re: VAFC wiring diagram for OBD0 CRX? (Blown90hatcH)
Thanks, but do you have the actual visual diagram?
Old 12-06-2003, 03:25 PM
VTEC4GS's Avatar
i usually go to the apexi-usa site and download the pdf file.
if you're confused about what to tap into vs cut then, map, vtec pres and vtec sol you cut, and power, rpm, etc you tap
greg
fryman
09-26-2008 08:03 PM
lYellowDragonl
12-13-2004 04:04 PM
CHRIS 1.8
06-22-2004 09:38 AM
triceeetrev
09-10-2003 01:13 PM
noricercrx
05-06-2002 08:18 PM
Quick Reply: VAFC wiring diagram for OBD0 CRX?
