Ek SFWD never ending build.....
Old 03-21-2016, 01:53 PM
  #51
kr3w108's Avatar
Default Re: Ek SFWD never ending build.....
Originally Posted by turbohatch96y7
Didnt even know you had a build thread
Looks nice man!
Yessir !
Old 03-22-2016, 08:21 PM
  #52
K20zwally's Avatar
Your build thread makes me wanna hurry up and finish my car..but then I remember that i don't have your kind of money 😞 Good luck on them 8's buddy
Old 03-22-2016, 08:43 PM
  #53
kr3w108's Avatar
Thanks man, i work a lot of hours to afford this stuff.... Will be worth it in the end..
Its all about having fun. I enjoy doing this .
Old 03-23-2016, 01:57 PM
  #54
kr3w108's Avatar
A little welding this morning .......
Old 03-24-2016, 07:23 PM
  #55
kr3w108's Avatar
Little by little i will finish this thing.....
Got the up pipe all welded, and had to modify the dump tubes to make them work with the new 4" exhaust . Need to shorten the up pipe and extend the dumps to make them all even ......
Old 03-26-2016, 08:58 AM
  #56
SPOOLINmatt's Avatar
movin along!
Old 03-26-2016, 11:30 AM
  #57
kr3w108's Avatar
Added some filters to a catch can that i made for my car a few months ago. Finally got around to finishing it......
Old 03-29-2016, 10:13 AM
  #58
ekcivicf20b's Avatar
Hell yea man. Looks great! Definitely kicking it in the *** and making progress. I like it!
Old 03-30-2016, 07:40 PM
  #59
kr3w108's Avatar
Sooooo... little update. I shipped that pile of crap Junk 2 shifter back for a refund. In its place i ordered a ktuned shifter and cables . I should have done this from the start and not had to waste my time with Junk 2 products......
Old 03-31-2016, 04:58 AM
  #60
ievaq8's Avatar
amazing build man, I just read it from start to progress post...
keep it up man, and I really love how u have put most of if not all the trims bak in...
just how I like it
Old 04-03-2016, 06:46 PM
  #61
GoldieWang's Avatar
I thought you liked that Skunk 2 shifter? Did it bind up or something?
Old 04-03-2016, 07:36 PM
  #62
kr3w108's Avatar
Yes it would bind up , and it would 1-2-1 shift . I had to put a spring on it to make it to make it shift correctly . The quality of of shifter is decent .... There are a few areas that are pretty crappy and needs some attention. There are spots that will eventually wear it's self out . I've only shifted the thing outside of the car and a few times inside . Never raced it and it already had pretty bad wear marks on it .. I would not suggest buying this shifter .
The new Ktuned with all the lockouts will be way better and in the long run will outlast with no issues .
Old 04-03-2016, 07:56 PM
  #63
kr3w108's Avatar
Well got the motor running this weekend .... Painted the comp housing and the intercooler pipes . I think it turned out really well. Makes the car look totally different .
Got some new rubber in for the dyno and possible street use ..... Mikey Thompson 275/50/15 it's a 25.9" inch tire. Look really big, not sure how it will fit lol I have a 15/8.25 0 offset rim to mount them on. Will get them mounted and see what I need to do .
Sooooooo onto some bad news ......... Got the car running yay! Lol motor runs great starts up on the first try with no issues. I'm getting a check engine light for a cam phase gap error . Took valve cover off and checked the timing and it is off by about a half tooth. Timing isn't off much but enough to throw a code ,Not really happy about this . With the motor at tdc the intake cam gear is off . The exhaust Lines up perfectly but not so much for intake.... I'm gonna order new chain guides in the morning for I used my old ones . No idea how it's that far off but it is .
Any idea as to what could cause this ? I'm gonna replace the guides and hope for the best ! I originally set all the marks on the chain so it's mechanically in time. With that said it has to be something else . I'm leaning towards worn guides .....
Old 04-04-2016, 05:57 AM
  #64
jayswizz's Avatar
perhaps a stretched chain??
Old 04-04-2016, 06:16 AM
  #65
I serve phở for my babies
ohsnapzafingcu's Avatar
dang, sorry for the luck! Glad the motor isn't hurt.
Old 04-04-2016, 07:04 AM
  #66
kr3w108's Avatar
Chain is new .
Old 04-04-2016, 08:52 AM
  #67
paulzy's Avatar
I've seen that before on some B-series. Was due to machining both head and block
Old 04-04-2016, 10:12 AM
  #68
kr3w108's Avatar
Head I pulled off a factory sealed motor and had resurfaced when Head was ported. The block I don't know if it has been milled before prior to having GE sleeves installed.
Old 04-05-2016, 08:16 PM
  #69
kr3w108's Avatar
G
Old 04-05-2016, 08:32 PM
  #70
kr3w108's Avatar
So after ordering new timing chain guides and redoing the timing I got the issue fixed and the car back running with zero CEL's .
Here is a short vid of the car idling . I could listen to this all day long !
Old 04-06-2016, 05:19 AM
  #71
JDMarv's Avatar
hooray :D
Old 04-06-2016, 08:12 AM
  #72
kr3w108's Avatar
Oh and just and FYI those Radials were a fail
I just ended up ordering a set of 225/50/15 Mickey Thompson. Those should be enough for the dyno. I was wanting to have a nice street tire that would hook at my power level but guess not... haha There was too much involved with getting those tires to fit. I am not going to change my suspension setup just to fit some radials when I already have the car setup for the track on my slicks.
Old 04-06-2016, 08:14 AM
  #73
JDMarv's Avatar
those were massive lol not surprised.
Old 04-06-2016, 09:41 AM
  #74
95B18BTurbo's Avatar
Damn nice build!
Old 04-09-2016, 11:38 AM
  #75
kr3w108's Avatar
#streetcar ..... Lol got the new 225/50/15 et street R's on they look pretty good on there . Got to finish the catch can coolant over flow , install my hood beauty ring, paint hood , scale car then get this bitch alighned . After that it's dyno time and I'll be ready to rip up the track . I can't wait !!!
Quick Reply: Ek SFWD never ending build.....
