Davila's 67mm H2B Midwest killer build
Old 01-11-2017, 05:35 PM
  #651
DraginX's Avatar
Default Re: Davila's 67mm H2B Midwest killer build
Love coming back into Honda Tech to see updates on this thread. Keep it up Jamie, good work!! And congrats on the wins!
Old 01-12-2017, 08:49 AM
  #652
h-duced's Avatar
Thank you!
Old 01-13-2017, 12:15 PM
  #653
military's Avatar
Originally Posted by h-duced
no, no and no
mine is 90mm on dartons with stock stroke
Old 02-14-2017, 01:18 PM
  #654
h-duced's Avatar
The new power plant aka the UNICORN. What is it? Basically a destroked version of the H22 that will allow us to take advantage of a 35mm intake valve above 10,000 RPM. Destroker rods, Outlaw spec pistons, and the words best machine work from 4-Piston Racing and Darton East. The plan is to DO WORK in 2017. #BUSLENGTHS2017 #BLACKHEART #KSTUNED
  #655
h-duced's Avatar
Old 02-14-2017, 01:26 PM
  #656
h-duced's Avatar
Old 02-15-2017, 05:57 AM
  #657
Moderator
snobordboy's Avatar
Just curious, anything special done to the oil pump, or is stock with the BS delete plugs?
Old 02-15-2017, 06:15 AM
  #658
h-duced's Avatar
Stock pump with KS delete plugs, that's it.
Old 02-16-2017, 12:34 PM
  #659
ESP.net's Avatar
Why not go H23V Blue Top Jaime? 55mm mains 95mm stroke and a 10 lbs lighter crank
De stroked enlighten me? So you have a custom shorter H22 rod? H23? With a taller compression height piston?
Still baby boost beating that twin I got from you
Old 02-16-2017, 02:34 PM
  #660
h-duced's Avatar
95mm stroke is terrible for high RPM power and with a 85mm hot side, we need RPM to do it's thang. Custom rods and outlaw spec pistons.
Old 02-16-2017, 02:39 PM
  #661
ESP.net's Avatar
I would agree with you on 95mm stroke on high RPM if the crank wasn't 10 lbs lighter... Older heavier H23A1 less stouter crank I would agree... but H23V is a nice piece it's younger and stronger brother
Old 02-16-2017, 03:02 PM
  #662
Jun Villaruz's Avatar
One word.. STOKED! It's single cam Jun
Old 02-16-2017, 03:19 PM
  #663
bluehbcivic's Avatar
The h23a crank weighs the same as the f20b.. i have both in hands there is not 10lb difference lol
crazy work Jamie cant wait to see how it goes down the track!!!
Old 02-16-2017, 03:24 PM
  #664
h-duced's Avatar
JUUUUUUUNNNNNNN!!!! What's up buddy?!
Old 02-16-2017, 03:27 PM
  #665
All is good trying to get Tim's car situated and busy with my build as well. I can't wait for the season to start!
Old 02-17-2017, 11:11 AM
  #666
ESP.net's Avatar
F20B crank weighs 36 lbs and my scale told me 33 lbs on my h23aV when I weighed it... give or take a lb....H23A1 weighs 38/39 lbs... From my records H22A Crank 50mm weighs 43 lbs and 55mm weighs 41 lbs
Old 02-18-2017, 04:39 PM
  #667
turbo1.5's Avatar
Such a sick build! Can't wait to see more!
Old 02-20-2017, 01:29 PM
  #668
h-duced's Avatar
Thank you!
Old 02-21-2017, 07:47 AM
  #669
JDMarv's Avatar
this is gonna be niceeeeeeeeee
Old 02-21-2017, 10:19 AM
  #670
h-duced's Avatar
Thank you!
Old 02-23-2017, 09:33 AM
  #671
kr3w108's Avatar
This build looks promising, Keep up the Good work !
Old 02-23-2017, 04:06 PM
  #672
hondatech8798's Avatar
Couple questions
the Web rocker arms how do they stack up against a full roller? Is there any advantage with them or just mainly due to your cam choice
And also did u install a oil restrict in the big end of the rod? Curious as to what it is
Thanks
Amazing build and attention to detail
Old 04-04-2017, 04:24 AM
  #673
h-duced's Avatar
Originally Posted by hondatech8798
Couple questions
Thanks
I have never done a comparison on the roller rockers, and for the Webb rockers, you are correct.
BME rods are pinned to help hold the bearing in place.
Thanks!
Old 04-04-2017, 04:53 AM
  #674
h-duced's Avatar
A little update, the trans is freshened up for the 2017 season, we switched to a billet housing hopefully this one hold up. A couple of new things happened to the trans this time around. Most obvious the billet housing, new ppg gear set with a 4.2 final, and last but not least, a input shaft sensor
Old 04-04-2017, 05:18 AM
  #675
Steve at Heart
Bently_Coop's Avatar
Shiny.
Quick Reply: Davila's 67mm H2B Midwest killer build
