Good Line lock instead of staging brakes.
Old 06-15-2013, 08:54 PM
K20EF8Dx's Avatar
Default Good Line lock instead of staging brakes.
I am wanting to keep my rear brakes working instead of running a stage brake. I have been looking but most of the line locks i have seen have one port in and one out is there any with 2 ports in and 2 out?
Anyone successfully loading their car at the line with a lock instead of a stage brake cause as of late it seems everyone is just running a SB. I see them both working correctly (both still using the same amount of brake pressure), but when i let go of the button i will still have my rear brakes with the line lock. any input?
Old 06-16-2013, 02:05 AM
rudebwoy's Avatar
Default Re: Good Line lock instead of staging brakes.
why not use 2 line lock solenoids one to each rear brake, and wire the activation switch parallel, this is what I am thinking of trying.
Old 06-16-2013, 06:18 AM
88h22_CRX's Avatar
My line lock is wired into the ebrake. I set the ebrake and pump the brakes 3 times and the pressure is held in it. Once burnout is going I release the ebrake and the line lock disengages.
Old 06-16-2013, 02:38 PM
K20EF8Dx's Avatar
I was thinking the same but to save space it would be easy to have 1 vs 2 solenoids.
Thats a good way to do it. I was thinking either steering wheel button or button on the shifter something i can let go of fast when leaving the line.
Old 06-16-2013, 05:35 PM
redboost10's Avatar
Instead of using two solenoids, why not T the one outlet to each wheel?
Old 06-17-2013, 03:19 AM
rudebwoy's Avatar
the line lock solenoids usually have 1 inlet 3 outlets, so you have to T the inlet and I want them independent, if you could find one with 2 inlet would be nice.
Old 06-17-2013, 02:36 PM
redboost10's Avatar
Most have one inlet and one outlet.
What's the benefit to keep them seperate?
Old 06-17-2013, 05:04 PM
K20EF8Dx's Avatar
Second this as i see no real benifite to having 2 solenoids vs 1. same amoutn of brake pressure will be applied either way.
JBLAZE622
12-31-2008 06:02 PM
Championship
07-17-2007 10:52 AM
evans_art
06-20-2007 12:46 PM
dmotoguy
10-02-2003 04:44 PM
AlphaKennyWun
02-26-2002 03:11 PM
Quick Reply: Good Line lock instead of staging brakes.
